.NET
Distinguished Contributor
Patrick Johnson
Message 1 of 3 (116 Views)
Custom properties
116 Views, 2 Replies
11-03-2006 11:36 AM
How do you go about updating customproperties?
I see you can use the IDictionaryEnumerator and loop thru the collection, however this is only read only.
thanks
pat
dmarcotte4
Message 2 of 3 (116 Views)
Re: Custom properties
11-03-2006 12:12 PM in reply to: Patrick Johnson
I have always used com for this
I would like to learn a .net way though
AcadDocument doc = (AcadDocument)AcadApp.DocumentManager.MdiActiveDocument.AcadDocument;
doc.SummaryInfo.SetCustomByKey(key, val)
doc.SummaryInfo.AddCustomInfo(key, val) Message was edited by: Danielm
Patrick Johnson
Message 3 of 3 (116 Views)
11-03-2006 12:23 PM in reply to: Patrick Johnson
I did figure it out, here is a snapshot of the code
Private Sub btnUpdate_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnUpdate.Click
Dim DB As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim objSumBuilder As New DatabaseSummaryInfoBuilder
Try
objSumBuilder.Author = txtDrafter.Text
objSumBuilder.Title = txtCustomer.Text
objSumBuilder.CustomProperties.Item("Office") = "test"
objSumBuilder.CustomProperties.Item("Checker") = "test1"
DB.SummaryInfo = objSumBuilder.ToDatabaseSummaryInfo
Catch ex As Exception
MsgBox(ex.Message, MsgBoxStyle.OkOnly, "Exception")
Finally
objSumBuilder = Nothing
End Try
the custom properties I just called the key and set the value.
It worked, I did learn something - it writes over the top so if there is information there you need to make sure you add it back in.
pat
End Sub
Announcements
Need installation help?
