.NET
chiefbraincloud
Message 11 of 19 (672 Views)
Re: Custom Commands within Namespace
05-07-2012 10:31 AM in reply to: norman.yuan
Yes, The SDK is incorrect.  It is possible that it used to be correct, but based on Kean's post, it has been incorrect since at least ACAD 2010.  (And I was looking at the 2013 SDK, It says the same thing going all the way back to 2009 SDK, at least)
I was always aware that if you had (any) CommandClass Attribute in your assembly, then only commands in that (those) class(es) would be found.
Until today, I thought there could be only one, that is the part the help files mislead me on.
I still have a question regarding Modules.  I have many commands in Modules.  Most of them in fact.  The only commands I have in classes are commands where an instance of the class needs to be created (like forms, or jigs), and even in some of those cases, I have a short CommandMethod in a Module that handles creating and destroying the instance of the Class.
I am relatively certain that I can not apply a CommandClass Attribute to a Module, so I guess that means I am either stuck leaving my code the way it is, or I have to change my Modules to classes, which I don't want to do.
norman.yuan
Message 12 of 19 (665 Views)
05-07-2012 12:51 PM in reply to: chiefbraincloud
Module in VB.NET is alsoa class, which is equivalent to C# static class. That is, all the methods in Module are static/Shared method.
Yes, you can place <Assembly: CommandClass(...)> in Module, just as you place on top of a class. And yes, it is the same as with multiple CommandClass, you also use multiple <Assembly: CommandClass(...)>. However, my test does reveil ONE THING: <Assembly: CommandClass(GetType(NamesapceName.ModuleName))> is required if the commandmethod is in a module, not a class, this is different from C#. So, although I said in VB.NET, Module is also a class, but AutoCAD does not search module for CommandMethod, unless the module is decorated with <Assembly: CommandClass(...)>.
Another point one may want to pay attention when place CommandMethod iin VB.NET Module: all methods in module is static/Shared method. While in Acad .NET API, there is different when commandmethod is declared as static/Shared, or not. If one want to take advantage of non-static/Shared commandmethod (i.e. get the CommandClass instantiated per document, instead of against all document, then one cannot use Module. So, in general, I would not recommed to use Module to declare commandmethod, unless you absolutely know that you do not need document-level of commandClass instance. But why impose such self-limitation?
Here is the code I tested in VB.NET Module:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(CommadClassInVBModuleTest.CommandModule1))>
<Assembly: CommandClass(GetType(CommadClassInVBModuleTest.CommandModule2))>
Module CommandModule1
    <CommandMethod("MyCmd1")> _
    Public Sub DoCommand1()
        Dim dwg As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = dwg.Editor
        ed.WriteMessage(vbCrLf & "Command in CommandModule1" & vbCrLf)
    End Sub
End Module
Module CommandModule2
    <CommandMethod("MyCmd2")> _
        ed.WriteMessage(vbCrLf & "Command in CommandModule2" & vbCrLf)
    End Sub
End Module
chiefbraincloud
Message 13 of 19 (664 Views)
05-07-2012 01:02 PM in reply to: norman.yuan
"but AutoCAD does not search module for CommandMethod, unless the module is decorated with <Assembly: CommandClass(...)>."
I'm not sure how you arrived at that conclusion, but I speak from (plenty of) experience, Commands in a Module will be found without the CommandClass Attribute.  I have at least one Module in every assembly I have, and there are no CommandClasss Attributes in any of those assemblies (because I thought you could only have one, or none).
My module commands get loaded just fine.  (As I commented earlier in the thread, the Module does have to be declared Public, which is not the default)
norman.yuan
Message 14 of 19 (661 Views)
05-07-2012 01:21 PM in reply to: chiefbraincloud
If you run the VB.NET code in my previous reply by commenting out the <Assembly: CommandClass...> on top of the module, AutoCAD will not find the 2 ommand(MyCmd1 and MyCmd2): the usual "Unknown command "xxxx" message is shown at command line.
I tested with AutoCAD Map2012, 64bit on Win7.
chiefbraincloud
Message 15 of 19 (660 Views)
05-07-2012 01:24 PM in reply to: norman.yuan
Those modules are not Public.
Add the Public Modifier, comment out your CommandClass attributes and AutoCAD will find the commands.
Valued Mentor
DiningPhilosopher
Message 16 of 19 (610 Views)
08-12-2012 08:59 PM in reply to: chiefbraincloud
chiefbraincloud wrote:
This is a Quote from the ObjectARX SDK, AutoCAD Managed Class Reference.
"This custom attribute class is used to mark a type as the application's command class. An application may designate one, and only one, type as its command class. AutoCAD looks for an application's command methods on the type that bears this attribute."
While I agree with those that think the help files are incomplete, I've not known them to lie to me before.
The help files are wrong, and please don't make the mistake of giving them the same legitimacy as one might give holy books. I've lost count of how many errata I've found (and been bitten by) in the managed API docs, not to mention the sample applications, labs, and so forth.
It also might help if you knew that if that was the intention (allow only one CommandClassAttribute per assembly), then the designer would have specified the AllowMultiple=false property in the [AttributeUsage] attribute applied to the CommandClassAttribute's definition (from Reflector):
[AttributeUsage(AttributeTargets.Assembly, AllowMultiple=true, Inherited=false)]
public sealed class CommandClassAttribute : Attribute
   // Fields
   private Type type_;
   // Methods
   public CommandClassAttribute(Type name);
   // Properties
   public Type Type { get; }
Active Contributor
thoman999
Message 17 of 19 (447 Views)
04-24-2013 05:57 PM in reply to: chiefbraincloud
I know this is an old thread but I'll post anyway just for searchers.
In working with Map3D 2013 the <CommandMethod ...> directive is not covered by the acmgd.dll and acdbmgd.dll references. I also had to load accoremgd.dll
Just an observation
tom
chiefbraincloud
Message 18 of 19 (438 Views)
04-24-2013 08:36 PM in reply to: thoman999
Yes, that is new to the 2013 API.
Valued Mentor
jeff
Message 19 of 19 (421 Views)
04-25-2013 11:15 PM in reply to: chiefbraincloud
If you look at code in link from reflector you see how Autocad loads your assembly and explains results.
--Checks is assembly contains CommandClassAttribute if it does it will check only the classes defined in each attribute and if not will examine each type in the assembly
http://www.theswamp.org/index.php?topic=44237.msg494891#msg494891
You can also find your answers @ TheSwamp
