Hi all,
using Autocad 2010 x64 on win7, I create a CommandMethod that scan document to search Hatches. When i get a Hatch object and then HatchLoop object trough GetLoopAt method, then the property Curves of the Curve2dCollection object return always null.
It should seem a bug. This happens also with Autocad 2009.
Does anyone knows something about this issue?
thanks in advance
Sorry.. Curves property is of HatchLoop object, not of Curve2dCollection.
mi code (c#) is:
foreach (ObjectId acObjId in acBlkTblRec)
if (acObjId.ObjectClass.Name.ToUpper() == "ACDBHATCH")
nCnt = nCnt + 1;
DBObject dbO = acObjId.GetObject(OpenMode.ForRead);
Hatch h = (Hatch)dbO;
for (int i = 0; i <= h.NumberOfLoops - 1; i++)
HatchLoop hl = h.GetLoopAt(i);
Curve2dCollection curves = hl.Curves;
hl.Curves is null (but the curves exist!!!), that's my problem
[CommandMethod("ht")] public static void HatchLoop() { PromptSelectionResult res = SysVarManager.Editor.GetSelection( new PromptSelectionOptions(), new SelectionFilter(new TypedValue[] { new TypedValue(0, "Hatch") })); if (res.Status != PromptStatus.OK) return; Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject( db.CurrentSpaceId, OpenMode.ForWrite, false); foreach (ObjectId id in res.Value.GetObjectIds()) { Hatch h = (Hatch)tr.GetObject(id, OpenMode.ForRead); Matrix3d mat = Matrix3d.PlaneToWorld(h.GetPlane()); for (int i = 0; i < h.NumberOfLoops; i++) { HatchLoop loop = h.GetLoopAt(i); if (loop.IsPolyline) { BulgeVertexCollection bvs = loop.Polyline; Autodesk.AutoCAD.DatabaseServices.Polyline pl = new Autodesk.AutoCAD.DatabaseServices.Polyline(); for (int j = 0; j < bvs.Count; j++) { BulgeVertex bv = bvs[j]; pl.AddVertexAt(j, bv.Vertex, bv.Bulge, 0, 0); } pl.TransformBy(mat); btr.AppendEntity(pl); tr.AddNewlyCreatedDBObject(pl, true); } else { foreach (Curve2d c2d in loop.Curves) { Curve c = c2d.ToCurve(mat); btr.AppendEntity(c); tr.AddNewlyCreatedDBObject(c, true); } } } } tr.Commit(); } }
