.NET
Current space?
3 REPLIES 3
408 Views, 3 Replies
Current space?
How do you determine th current space using dotnet?
I'm looking for the equivalent VB dotnet code to this VBA code:
'VBA:
If ThisDrawing.ActiveSpace = acModelSpace Then
MsgBox("currently in the Model tab")
Else
If ThisDrawing.MSpace = True Then
MsgBox("currently in the model space of a paper space viewport")
Else
MsgBox("currently in paper space")
End If
End If
Thx.
Kevin.
3 REPLIES 3
RonnieWilkins
Autodesk.AutoCAD.DatabaseServices.Database.CurrentSpaceId
Rough outline:
Dim DB as Autodesk.AutoCAD.DatabaseServices.Database
Dim TM as Autodesk.AutoCAD.DatabaseServices.TransactionManager
Dim CT as Autodesk.AutoCAD.DatabaseServices.Transaction
DB = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
TM = DB.TransactionManager
CT = TM.StartTransaction
Dim BT as Autodesk.AutoCAD.DatabaseServices.BlockTable
BT = CT.GetObject(db.BlockTableID,ForRead)
Dim CurrentSpace as Autodesk.AutoCAD.DatabaseServices.BlockTableRecord
CurrentSpace = CT.GetObject(bt(DB.CurrentSpaceID),ForRead)
Ronnie Wilkins, Jr.
Thanks, but...
When I try to build the code you sent I get an error on this line:
CurrentSpace = CT.GetObject(bt(DB.CurrentSpaceID,ForRead)
error:
Value of type '... ObjectID' cannot be converted to string
db.currentspaceid being underlined in the code
Also, will this get to the property I am looking for? The program I am about to write needs to know which space is active in the current drawing - is it model space, paper space (a layout) or model space within a paper space viewport. That was achieved via properties of the current document in VBA.
Thanks for your help.
kwecker
For anyone else that stumbles upon this page looking for inserting on the current layout, this worked for me in any layout or model space. I use C# for my apps.
BlockTableRecord btr = (BlockTableRecord)tm.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
”Boost
