.NET
Current DimStyle
5 REPLIES 5
796 Views, 5 Replies
Current DimStyle
Hi, I am trying to find out what the current DimStyle of the drawing.
I have iterated through all DimStyle but can’t find any way of finding the current Style.
For Each DsrID In DST
     Dim R As DimStyleTableRecord = CType(DsrID.GetObject(OpenMode.ForRead), DBObject)
     Debug.Print(R.Name)
Next
 Please help.
Thank you.
Tags (1)
5 REPLIES 5
mzakiralam
try to get the what system variable "DIMSTYLE" returns. this system variable will return the current style. you can go through the below link for details of this system variable.
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ffa23ce210c4a30acaf-5041...
in reply to: mzakiralam
Thank you Mzakiralam for a quick response.
I am not sure if this will work because I am accessing the drawings without physically opening them. GetSystemVariable requires Applicatio
Dim str As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("DIMSYLE")
My only way currently accessing is via Database.
_gile
hi,
The Database class do have a Dimstyle property to access the ObjectId of the current dimstyle.
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Gilles, can you please show me an example.
in reply to: _gile
Gilles, I got it, thanks
Dim DimSyleID = Me._WorkingDB.Dimstyle
Dim DwgDimSyle As DimStyleTableRecord = CType(DimSyleID.GetObject(OpenMode.ForRead), DBObject)
 Thanks again
”Boost
