.NET
CUIX, CUI 2010 images not loading
6 REPLIES 6
dave.wolfe
570 Views, 6 Replies
I've created a program to load a partial CUI into another CUI outside of AutoCAD. Per the CUI documentation the code to load a partial cui is:
CustomizationSection maincui = new CustomizationSection(filename);
maincui.PartialCuiFiles.Add(filenameofpartial);
I've left out the checks to see if the partial CUI is loaded.
The partial that I am loaded contains ribbon tabs/panels that have the images for the commands stored in the CUIX file (new 2010 feature). However, when I use the code above to load the partial, the images all show up as clouds. If I load the same ribbon (copied to a different location) through AutoCAD, the images all show up fine.
Partial Fix:
If I extract the images and save them in a folder that is located in an AutoCAD support search path, they will show up correctly.
My conclusion:
I think the CUI API needs to be fixed so that AutoCAD looks for the images inside of the CUIX file. Since the images are not found, I conclude that AutoCAD performs the search to locate them in the CUIX, but the CUI API does not.
Has anybody found a way to load the partial cui files outside of AutoCAD so that the images show up correctly?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
6 REPLIES 6
in reply to: dave.wolfe
Are you trying to load a CUIX file or a CUI file?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6299440@discussion.autodesk.com...
Partial Fix:
My conclusion:
not.
dave.wolfe
Sorry, should've been more clear. All the files are CUIX.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
What happens if you manually load the partial .CUIX file using the CUI
dialog?
Are the images in the CUIX file found?
wrote in message news:6299718@discussion.autodesk.com...
dave.wolfe
Yes, working through AutoCAD using the CUI dialog works. It's only by using the API outside of AutoCAD that it doesn't work. The goal is to create an installation program that integrates my cui without user interaction (other than selecting a profile).
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
You should look at what AutoCAD does to the main CUI file when you use it to
load the partial, and see if you can identify something that isn't being
done or is done differently when you use the API.
wrote in message news:6299772@discussion.autodesk.com...
dave.wolfe
I've only found a couple things (none of which work)
1. The Header CUI file (from the extracted CUIX), the partial is listed by the file name only and not the full path.
2. The when load through AutoCAD the full path is stored in the registry in the profile Profilename\Dialogs\Select a file\FilenameMRU.
So I can't find anything in the CUIX file that shows a major difference. I changed the path to only the filename and I tried adding the path to the registry, and the images still were not located. I've used the Process Monitor exe to try to track down and see what happens. I did notice that AutoCAD will use the support file search path to locate the CUIX and load the first one it finds. However, even adding a support file search path to the cuix directory doesn't produce reliable results for loading the images.
My conclusion is that there is a bug in the loading mechanism. It'd be nice to be able to tell AutoCAD to look for images in the CUIX so it wouldn't try to load the from the normal methods. Any other suggestions would be welcome....I'm going bald trying to get this sorted out.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
”Boost
