.NET
Distinguished Contributor
1 Kudo
Post 1 of 12
Accepted Solution
Creating UCS and making it active.
280 Views, 11 Replies
08-29-2013 12:36 PM
Hi everyone, I am trying to create a new UCS and then making it active. The new UCS coordinate is
  Origin(0,0,0)
  X direction(1.8963581, 0.36861467, 0.51763809)
  Y direction(-0.190809, 0.98162718, 0.0)
Any help would be appreciated,
Thank you,
-J
It seems to me the vectors passed to the SetUcs() method aren't strictly perpendicular.
By my side, I'd calculate the vectors from the x one for more accuracy and get their normal (unit vector) before using them to create a Coordinate System.
Jeff's method
 [CommandMethod("FooUcs")]
public void FooUcs()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
Vector3d xaxis = new Vector3d(1.8963581, 0.36861467, 0.51763809);
Vector3d yaxis = new Vector3d(-0.190809, 0.98162718, 0.0);
xaxis = xaxis.GetNormal();
Vector3d zaxis = xaxis.CrossProduct(yaxis).GetNormal();
yaxis = zaxis.CrossProduct(xaxis).GetNormal();
using (Transaction trx = db.TransactionManager.StartTransaction())
ViewportTableRecord vtr = (ViewportTableRecord)ed.ActiveViewportId.GetObject(OpenMode.ForRead);
vtr.SetUcs(Point3d.Origin, xaxis, yaxis);
ed.UpdateTiledViewportsFromDatabase();
trx.Commit();
Another one:
 [CommandMethod("BarUcs", CommandFlags.Modal)]
public void BarUcs()
Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
ed.CurrentUserCoordinateSystem = Matrix3d.AlignCoordinateSystem(
Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
Point3d.Origin, xaxis, yaxis, zaxis);
Brilliant!!! Thank you.
Valued Mentor
53 Kudos
Post 2 of 12
Re: Creating UCS and making it active.
08-30-2013 01:15 AM in reply to: junoj
One way of setting UCS with information provided
You can get active viewport from from
Editor.ActiveViewportId Property
then use the overloaded version of SetUcs which creates a unnamed UCS
AbstractViewTableRecord.SetUcs(Point3d, Vector3d, Vector3d)  Method
and  then update it
Editor.UpdateTiledViewportsFromDatabase() Method
Example:
                    vtr.SetUcs(Point3d.Origin, new Vector3d(1.8963581, 0.36861467, 0.51763809), new Vector3d(-0.190809, 0.98162718, 0.0));
                    trx.Commit();
You can also find your answers @ TheSwamp
1 Kudo
Post 3 of 12
08-30-2013 09:07 AM in reply to: jeff
Thank you Jeff for your replay.
When I run you code I get an error: eBadUCS. I have attached a picture of the error
Valued Mentor
53 Kudos
Post 4 of 12
08-30-2013 03:08 PM in reply to: junoj
Not sure why,
What year are you using and version, and can you load up a empty drawing with same visual settings?
1 Kudo
Post 5 of 12
08-30-2013 03:12 PM in reply to: jeff
I am using:
  • Visual Studio 2008
  • AutoCAD 2011
  • OS Win 7 32bit
The drawing I am loading into is just a blank CAD drawing
Valued Mentor
53 Kudos
Post 6 of 12
08-30-2013 06:03 PM in reply to: junoj
Using 2013 maybe someone else with 2011 can try, but if you not get an answer would load up drawing because blank drawings can be very different with the 1,000 different variables for AutoCAD.
And to prove my point I just set UCSFOLLOW to 1 and got same error.
Try again with UCSFOLLOW set to 0 to see if it works and then might need to create named or anonymous UcsTableRecord then use overloaded SetUCS version that takes the objectid of UcsTableRecord.
Someone else might have a better way and I might be steering you in wrong direction.
*Expert Elite*
255 Kudos
Post 7 of 12
08-31-2013 12:29 AM in reply to: jeff
Jeff's method
                trx.Commit();
Another one:
Gilles Chanteau
*Expert Elite*
255 Kudos
Post 8 of 12
08-31-2013 04:28 AM in reply to: _gile
The calls to GetNormal() method does not seem mandatory.
            Vector3d zaxis = xaxis.CrossProduct(yaxis);
            yaxis = zaxis.CrossProduct(xaxis);
                trx.Commit();
Gilles Chanteau
1 Kudo
Post 9 of 12
08-31-2013 12:12 PM in reply to: _gile
Thank you Jeff and Gilles for all the help, I have learned a lot from this post.
The CrossProduct was the answer !!!!!
It has been some time the last time I used vectors . . . I had to consult with KhanAcademy. I am still trying to understand what will ‘ .GetNormal()’  function actually return vs. CrossProduct ?
Thank you,
-J
1 Kudo
Post 10 of 12
09-11-2013 01:40 AM in reply to: junoj
Hi Gilles,
You “BarUcs” works to change the orientation of the UCS very nicely. But for the life if me I cannot understand how to move the usc.
Do I have to provide the matrix origin or is it possible to change the origin after the fact (after the ucs has been aligned )
Thank you.
-Jay
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
