.NET
Valued Mentor
19 Kudos
Post 1 of 6
Creating Sliding Grip
341 Views, 5 Replies
01-24-2013 01:55 AM
Hi
I am wanting to make a grip that slides along a polyline. Similar to the diamond shaped grips used in Civil3d to slide along alignments and pipe objects to pick stations and insert labels. Does anyone know how this can be done in .net.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Guys
Thanks for the suggestions, I also found this post by Norman that looks good as well. I guess the code final will be a mixer of all these suggestions
http://drive-cad-with-code.blogspot.co.nz/2012/03/moving-entity-along-curve.html
171 Kudos
Post 2 of 6
Re: Creating Sliding Grip
01-24-2013 12:45 PM in reply to: ralstogj
Dou you want to draw something similar on this shape?
        public void drawDMShape()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            Line ln = new Line();
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                double[] x = new double[61];
                double[] y = new double[61];
                int i = 0;
                int j = 0;
                int k = 0;
                double theta = 0;
                double t = 100;
                double _pi = Math.PI;
                k = 15;
                theta = 2 * _pi / k;
                for (i = 0; i <= k; i++)
                    x[i] = t * Math.Cos(theta * (i + 1)) + 200;
                    y[i] = 200 - t * Math.Sin(theta * (i + 1));
                for (i = 0; i <= k - 1; i++)
                    for (j = i + 1; j <= k; j++)
                        ln = new Line(new Point3d(x[i], y[i], 0), new Point3d(x[j], y[j], 0));
                        btr.AppendEntity(ln);
                        tr.AddNewlyCreatedDBObject(ln, true);
                tr.Commit();
Valued Contributor
5 Kudos
Post 3 of 6
01-24-2013 01:57 PM in reply to: Hallex
I am not sure if I understood correctly what you mean.
If you mean grip points then I used ideas from this link
http://www.theswamp.org/index.php?topic=42974.0
Richard
Valued Mentor
19 Kudos
Post 4 of 6
01-24-2013 03:58 PM in reply to: ralstogj
Guys
Here is a picture from Civil3d of the sliding grip for a pipe label used to move the pipe label up and down the pipe.
Basically I want to copy this type of grip and use it to slide up and down the pipe, but instead of a label attached to the grip I will have a short piece of pipe that is the house lot connections angled at 45 degrees to the main pipe line.
Regards
Justin Ralston
Valued Contributor
5 Kudos
Post 5 of 6
01-24-2013 04:50 PM in reply to: ralstogj
I am not very familiar with C3D but the way how to add new grip point is by using  overrule api.
If I were you I would check this links
-Monitoring grip edit and then move your short pipe
http://through-the-interface.typepad.com/through_the_interface/2009/08/gluing-a-point-to-an-autocad-...
-Add new diamond grip point
Richard
Valued Mentor
19 Kudos
Post 6 of 6
01-25-2013 01:58 AM in reply to: ralstogj
Guys
Regards
Justin Ralston
