.NET
Creating polyline in random plane
3 REPLIES 3
junoj
395 Views, 3 Replies
Hi everyone,
I would like to create a polyline in a plane that is not WCS. I am able to do so with the 3D polyline. My problem is that 3D polyline does not allow for a Bulge in the polyline.
Please advice,
Thank you.
3 REPLIES 3
augusto.goncalves
in reply to: junoj
The Polyline don't have Z information, only a Elevation, so it can only be at a XY plane.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
junoj
in reply to: augusto.goncalves
Thank you Augusto for your reply. So is it possible for me to change the UCS prior to creating the polyline?
Thank you again,
_gile
in reply to: junoj
Except if you're using the "_PLINE" command  (with SendStringToExecute or SendCommand, ...) your program won't care about current UCS.
Use the Polyline Normal and Elevation properties or the TransformBy() method.
Gilles Chanteau
GileCAD
GitHub
”Boost
