.NET
Valued Contributor
RamanSBV
Message 1 of 5 (308 Views)
Creating new drawing file.
308 Views, 4 Replies
04-22-2012 11:59 PM
How I can create new drawing(.dwg) file using drawing template(.dwt)file in back end (Means with out showing in front end).
Thanks in advance...
Rama
Alfred.NESWADBA
Message 2 of 5 (307 Views)
Re: Creating new drawing file.
04-23-2012 12:04 AM in reply to: RamanSBV
if you want to create a new database (so you don't open it in the AutoCAD-Editor) you can use:
Public Sub New(buildDefaultDrawing As Boolean, noDocument As Boolean)
     Member von Autodesk.AutoCAD.DatabaseServices.Database
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 3 of 5 (306 Views)
04-23-2012 12:08 AM in reply to: Alfred.NESWADBA
Thanks for your response...
Please tell me how can use tempalate in this statement
Raman
Alfred.NESWADBA
Message 4 of 5 (299 Views)
04-23-2012 12:15 AM in reply to: RamanSBV
You can insert your template (or parts of it) in the new database (using WBLOCKCLONEOBJECTS or simililar funcionality).
You can also create a new database and do then DatabaseObj.ReadDwgFile to get the template-data into the new database-object and then -SaveAs to a new DWG.
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 5 of 5 (298 Views)
04-23-2012 12:24 AM in reply to: RamanSBV
db.ReadDwgFile("<path to template file>",...)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
