.NET
Creating new drawing file.
4 REPLIES 4
674 Views, 4 Replies
How I can create new drawing(.dwg) file using drawing template(.dwt)file in back end (Means with out showing in front end).
Thanks in advance...
Rama
4 REPLIES 4
Alfred.NESWADBA
if you want to create a new database (so you don't open it in the AutoCAD-Editor) you can use:
Public Sub New(buildDefaultDrawing As Boolean, noDocument As Boolean)
     Member von Autodesk.AutoCAD.DatabaseServices.Database
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for your response...
Please tell me how can use tempalate in this statement
Raman
Alfred.NESWADBA
You can insert your template (or parts of it) in the new database (using WBLOCKCLONEOBJECTS or simililar funcionality).
You can also create a new database and do then DatabaseObj.ReadDwgFile to get the template-data into the new database-object and then -SaveAs to a new DWG.
- alfred -
Alfred NESWADBA
Alexander.Rivilis
db.ReadDwgFile("<path to template file>",...)
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
