.NET
Valued Contributor
RamanSBV
Message 1 of 5 (320 Views)
Creating new drawing file.
320 Views, 4 Replies
04-22-2012 11:59 PM
How I can create new drawing(.dwg) file using drawing template(.dwt)file in back end (Means with out showing in front end).
Thanks in advance...
Rama
>> Please tell me how can use tempalate in this statement
You can insert your template (or parts of it) in the new database (using WBLOCKCLONEOBJECTS or simililar funcionality).
You can also create a new database and do then DatabaseObj.ReadDwgFile to get the template-data into the new database-object and then -SaveAs to a new DWG.
- alfred -
db.ReadDwgFile("<path to template file>",...)
Alfred.NESWADBA
Message 2 of 5 (319 Views)
Re: Creating new drawing file.
04-23-2012 12:04 AM in reply to: RamanSBV
if you want to create a new database (so you don't open it in the AutoCAD-Editor) you can use:
Public Sub New(buildDefaultDrawing As Boolean, noDocument As Boolean)
     Member von Autodesk.AutoCAD.DatabaseServices.Database
HTH, - alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 3 of 5 (318 Views)
04-23-2012 12:08 AM in reply to: Alfred.NESWADBA
Thanks for your response...
Raman
Alfred.NESWADBA
Message 4 of 5 (311 Views)
04-23-2012 12:15 AM in reply to: RamanSBV
- alfred -
Alfred NESWADBA
Moderator
Alexander.Rivilis
Message 5 of 5 (310 Views)
04-23-2012 12:24 AM in reply to: RamanSBV
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
