.NET
Creating an instance of the COM component
2 REPLIES 2
1284 Views, 2 Replies
(visual studio 2010 c# and AutoCAD 2010 )
I`m trying to open a DWG file as follows.
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
AcadApplication gbl_app = null;
AcadDocument gbl_doc = null;
gbl_app = new AcadApplication();
gbl_doc = gbl_app.Documents.Open("c:\\fichero.dwg"true);
gbl_app.Visible = true;
and I get the following error
System.Runtime.InteropServices.COMException (0x80010001): Error al crear una instancia del componente COM con CLSID {6D7AE628-FF41-4CD3-91DD-34825BB1A251} desde IClassFactory debido al siguiente error: 80010001.
Tags (1)
2 REPLIES 2
Virupaksha_aithal
Hi
Below blog article should help you to resolve your issue
http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
Virupaksha Aithal
Autodesk Developer Network
Virupaksha Aithal KM
Developer Technical Services
Hello!your probelm  have to be  solved?   how to solve  this problem   can you guide me?
”Boost
