.NET
mgorecki
Message 1 of 6 (345 Views)
Creating an Icon to Launch a dll
345 Views, 5 Replies
02-20-2013 09:52 AM
I have a .net program that I would like to run using an icon.  I've done this before and it worked, but now it's giving me an error.
I created the icon and command, I added the following to the command line:
^C^Cnetload "C://Program Files//my stuff//myProgram.dll” adp
(adp will lanch the program)
I get the following:
netload Assembly file name: "C://Program
Files//mystuff//myProgram.dll” adp
Cannot load assembly. Error details: System.ArgumentException: Illegal
characters in path.
   at System.IO.Path.CheckInvalidPathChars(String path)
   at System.IO.Path.Combine(String path1, String path2)
   at ?A0xe1e1f031.NormalizeLoadFilename(String fname)
   at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   at loadmgd()
Originally I tried using single slashes (/), but it still gives the same error.  It seems to have trouble with the spaces in the file path.  How do I work around that?
norman.yuan
Message 2 of 6 (337 Views)
Re: Creating an Icon to Launch a dll
02-20-2013 10:31 AM in reply to: mgorecki
The file path in your macro is wrong: you use either double back-slash "\\" or single forward-slash "/". Yet, you used double forward-slash "//", hence the "illegal character in path"!
mgorecki
Message 3 of 6 (318 Views)
02-20-2013 12:00 PM in reply to: norman.yuan
When I use:
^C^Cnetload "C:\\Program Files\\my Stuff\\myProgram.dll” adp
I get:
Command: netload Assembly file name: "C:
characters in path.
   at loadmgd()
When I use:
^C^Cnetload "C:/Program Files/my Stuff/myProgram.dll” adp
I get:
Command: netload Assembly file name: "C:/Program Files/my
characters in path.
   at loadmgd()
It's so weird, it used to work with the single slashes.
mgorecki
Message 4 of 6 (315 Views)
02-20-2013 12:10 PM in reply to: norman.yuan
Ok, I just retyped the command very carefully:
^C^Cnetload "C:/Program Files/my Stuff/myProgram.dll" adp
For some reason, this one works.  Maybe a hidden character from a cut and paste?
Hallex
Message 5 of 6 (285 Views)
02-21-2013 03:03 AM in reply to: mgorecki
I'm using for years lisp expression for button macro,
i.e. for full path of my test .dll:
^C^C(command "_.NETLOAD" "C:/Users/Oleg/Programming/ACAD/ACAD_START/AutoCAD CSharp plug-in1/AutoCAD CSharp plug-in1/bin/Release/AutoCAD CSharp plug-in1.dll" )(princ)
 It should working for me with no problem,
as you can see your friend is a single slash as delimiter
mjsmith
Message 6 of 6 (140 Views)
08-07-2013 01:15 PM in reply to: mgorecki
The " character at the end of the string looks different than the one at the beginning I bet that is your illicit character causing the problem.
