.NET
NikWach
Message 1 of 3 (116 Views)
Creating a user defined style and attaching it to the dbEntity
116 Views, 2 Replies
09-19-2013 04:19 AM
Hello everyone!
I have got a following problem. Ich wrote a program to analize a text source, where you can find all draw entities. In this source file you have got all properties of those entities. Ich try to create a custom style and attach it to the ex. text entity. How can I do it?
Below you find the code, where I create the style and attach it to the entity.
'' Get the current document and database
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
'' Start a transaction
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
'' Open the Block table for read
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _
OpenMode.ForRead)
Dim ed As Editor = acDoc.Editor
Dim st As TextStyleTable = CType(acTrans.GetObject( _
acCurDb.TextStyleTableId, _
OpenMode.ForWrite, False), _
TextStyleTable)
Dim TextStyle As TextStyleTableRecord = _
New TextStyleTableRecord()
TextStyle.Name = "MyStyle"
st.Add(TextStyle)
'default text style properties
'str.FileName = "txt.shx"
'str.PriorSize = 0.2
'str.ObliquingAngle = 0.0
'str.XScale = 1.0
'str.TextSize = 0.0
'str.IsVertical = False
'str.IsShapeFile = False
'using the font descriptor to set the new font style
'Imports Autodesk.AutoCAD.GraphicsInterface
TextStyle.Font = New FontDescriptor("RomanC", True, True, Nothing, Nothing)
acTrans.AddNewlyCreatedDBObject(TextStyle, True)
'' Open the Block table record Model space for write
Dim acBlkTblRec As BlockTableRecord
acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
OpenMode.ForWrite)
'' Create Text Entities
For CollectionCount = 0 To Text_Collection.Count - 1
'' Create a single-line text object
Dim acText As DBText = New DBText()
acText.Position = New Point3d(Text_Collection(CollectionCount).PKT_X(0), Text_Collection(CollectionCount).PKT_Y(0), 0)
acText.Height = Text_Collection(CollectionCount).HOHE
acText.WidthFactor = Text_Collection(CollectionCount).X_SKAL
acText.Rotation = Text_Collection(CollectionCount).DREHUNG
acText.TextString = Text_Collection(CollectionCount).TEXT
acBlkTblRec.AppendEntity(acText)
acTrans.AddNewlyCreatedDBObject(acText, True)
Next
I need to attach the "MyStyle" to the acText Entity... It have to work the following way -
There is a collection of text entities. Each entity has it own text-color, font or what ever. I want while creating acText to use the each entity property for its own acText. I attach my VBProject and the source file with the properties.
Matti72
Message 2 of 3 (104 Views)
Re: Creating a user defined style and attaching it to the dbEntity
09-19-2013 05:29 AM in reply to: NikWach
Maybe I'm blind, but I can't find the place, where you attach the style to the text.
I miss a line like
acText.TextStyleId = TextStyle.ObjectId
this should normally do the trick.
NikWach
Message 3 of 3 (100 Views)
09-19-2013 05:41 AM in reply to: Matti72
Thanks a lot! It does work:smileywink:
Post to the Community
New Post
Need installation help?
