.NET
.NET
Active Contributor
btmcad
Message 1 of 7 (305 Views)
Creating a new layout from a template
305 Views, 6 Replies
06-28-2012 08:19 PM
I have a small project that I'm working on that inserts a new layout based on a user selected  template size (A, B, C or D sizes). I need the program to insert the layout along with the titleblock geometry from the existing A, B, C, or D dwt files.
I know how to add a new blank layout. However, I'm having some trouble determing how to insert the titleblock geomtry. I've read a number of posts on here related to layouts, and while they were informative, none of them covered exactly what I need to do. I'm having some trouble following the code for some of the solutions that I have seen.
I would greatly appreciate it if someone could provide some direction, or an explanation of the steps that I need to follow in order to write the proper code.
thanks
btm
In addition try this code, limited tested
you have to add check if file exist, if layout name
is not from your layout list etc:
 <CommandMethod("clayout", CommandFlags.Session)> _
Public Sub testCopyLayoutFromTemplate()
CopyLayoutFromTemplate("C:\Test\Temp2.dwt", "A")
End Sub
Public Sub CopyLayoutFromTemplate(ByVal filepath As String, ByVal layoutname As String)
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim curdb As Database = doc.Database
Dim ed As Editor = doc.Editor
Dim loc As DocumentLock = doc.LockDocument()
Using loc
Dim tr As Transaction = doc.TransactionManager.StartTransaction
Using tr
Try
Dim mLayoutmgr As LayoutManager = LayoutManager.Current
Dim newlayoutname As String = layoutname
Dim layoutId As ObjectId = ObjectId.Null
Dim btrId As ObjectId = ObjectId.Null
layoutId = mLayoutmgr.CreateLayout(newlayoutname)
Dim newlayout As Layout = DirectCast(tr.GetObject(layoutId, OpenMode.ForWrite), Layout)
Dim layoutbtr As BlockTableRecord = DirectCast(tr.GetObject(newlayout.BlockTableRecordId, OpenMode.ForWrite), BlockTableRecord)
btrId = layoutbtr.ObjectId
Dim btr As BlockTableRecord = CType(tr.GetObject(curdb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim exdb As Database = New Database(False, True)
Using exdb
Using extr As Transaction = exdb.TransactionManager.StartTransaction
exdb.ReadDwgFile(filepath, System.IO.FileShare.Read, False, "")
Dim layoutdict As DBDictionary = DirectCast(exdb.LayoutDictionaryId.GetObject(OpenMode.ForRead), DBDictionary)
Dim layout As Layout = DirectCast(layoutdict.GetAt(layoutname).GetObject(OpenMode.ForRead), Layout)
Dim exbtr As BlockTableRecord = DirectCast(extr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
Dim objcoll As ObjectIdCollection = New ObjectIdCollection
For Each id As ObjectId In exbtr
objcoll.Add(id)
Next
exdb.WblockCloneObjects(objcoll, btrId, New IdMapping, DuplicateRecordCloning.Ignore, False)
End Using
End Using
mLayoutmgr.CurrentLayout = newlayoutname
tr.Commit()
ed.Regen()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.ToString & vbCr & ex.Message)
End Try
End Using
End Using
End Sub
~'J'~
Hallex
Message 2 of 7 (297 Views)
Re: Creating a new layout from a template
06-29-2012 03:59 AM in reply to: btmcad
Try the code from this article:
http://adndevblog.typepad.com/autocad/2012/06/copy-a-layout-with-its-entities-from-one-drawing-to-an...
~'J'~
Active Contributor
btmcad
Message 3 of 7 (292 Views)
06-29-2012 05:11 AM in reply to: Hallex
Thanks Hallex,
That code works, but I'm more interested in learning to code the actual ".net" process of copying layouts from a .dwt to a current drawing. I'm fairly new to .net programming and I'm trying to learn as much as possible, as quickly as possible.
I've seen a few examples of similar programs, but I'm not following some of the code.
I know how to create new blank layout, and the code makes sense to me. I just don't know how to get the drawing objects, and other format related items into the new layout.
btm
Hallex
Message 4 of 7 (289 Views)
06-29-2012 06:00 AM in reply to: btmcad
To get objects from external drawing use WBlockCloneObjects method of Database,
this will allow you to copy what you need, just gather all of the objects from particular layout
you want to copy,
~'J'~
Hallex
Message 5 of 7 (283 Views)
06-29-2012 06:49 AM in reply to: Hallex
        End Sub
            Using loc
                Using tr
                    Try
                        Using exdb
                                    objcoll.Add(id)
                                Next
                            End Using
                        End Using
                        tr.Commit()
                        ed.Regen()
                    End Try
                End Using
            End Using
        End Sub
~'J'~
Active Contributor
btmcad
Message 6 of 7 (244 Views)
07-13-2012 08:37 AM in reply to: Hallex
Hallex,
I finally got back to working on this project. I tested the code that you posted above and it works great. I had to make a couple small adjustments for 2013, but otherwise, it worked as-is.
Thanks for the help. Your code is very clear and concise.
btm
Hallex
Message 7 of 7 (241 Views)
07-13-2012 08:43 AM in reply to: btmcad
Glad I could help,
Cheers :smileyhappy:
~'J'~
