.NET
Creating a new layout from a template
6 REPLIES 6
1457 Views, 6 Replies
I have a small project that I'm working on that inserts a new layout based on a user selected  template size (A, B, C or D sizes). I need the program to insert the layout along with the titleblock geometry from the existing A, B, C, or D dwt files.
I know how to add a new blank layout. However, I'm having some trouble determing how to insert the titleblock geomtry. I've read a number of posts on here related to layouts, and while they were informative, none of them covered exactly what I need to do. I'm having some trouble following the code for some of the solutions that I have seen.
I would greatly appreciate it if someone could provide some direction, or an explanation of the steps that I need to follow in order to write the proper code.
thanks
btm
6 REPLIES 6
Hallex
Try the code from this article:
http://adndevblog.typepad.com/autocad/2012/06/copy-a-layout-with-its-entities-from-one-drawing-to-an...
~'J'~
in reply to: Hallex
Thanks Hallex,
That code works, but I'm more interested in learning to code the actual ".net" process of copying layouts from a .dwt to a current drawing. I'm fairly new to .net programming and I'm trying to learn as much as possible, as quickly as possible.
I've seen a few examples of similar programs, but I'm not following some of the code.
I know how to create new blank layout, and the code makes sense to me. I just don't know how to get the drawing objects, and other format related items into the new layout.
btm
Hallex
To get objects from external drawing use WBlockCloneObjects method of Database,
this will allow you to copy what you need, just gather all of the objects from particular layout
you want to copy,
~'J'~
Hallex
in reply to: Hallex
In addition try this code, limited tested
you have to add check if file exist, if layout name
is not from your layout list etc:
        <CommandMethod("clayout", CommandFlags.Session)> _
        Public Sub testCopyLayoutFromTemplate()
            CopyLayoutFromTemplate("C:\Test\Temp2.dwt", "A")
        End Sub
        Public Sub CopyLayoutFromTemplate(ByVal filepath As String, ByVal layoutname As String)
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim curdb As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim loc As DocumentLock = doc.LockDocument()
            Using loc
                Dim tr As Transaction = doc.TransactionManager.StartTransaction
                Using tr
                    Try
                        Dim mLayoutmgr As LayoutManager = LayoutManager.Current
                        Dim newlayoutname As String = layoutname
                        Dim layoutId As ObjectId = ObjectId.Null
                        Dim btrId As ObjectId = ObjectId.Null
                        layoutId = mLayoutmgr.CreateLayout(newlayoutname)
                        Dim newlayout As Layout = DirectCast(tr.GetObject(layoutId, OpenMode.ForWrite), Layout)
                        Dim layoutbtr As BlockTableRecord = DirectCast(tr.GetObject(newlayout.BlockTableRecordId, OpenMode.ForWrite), BlockTableRecord)
                        btrId = layoutbtr.ObjectId
                        Dim btr As BlockTableRecord = CType(tr.GetObject(curdb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                        Dim exdb As Database = New Database(False, True)
                        Using exdb
                            Using extr As Transaction = exdb.TransactionManager.StartTransaction
                                exdb.ReadDwgFile(filepath, System.IO.FileShare.Read, False, "")
                                Dim layoutdict As DBDictionary = DirectCast(exdb.LayoutDictionaryId.GetObject(OpenMode.ForRead), DBDictionary)
                                Dim layout As Layout = DirectCast(layoutdict.GetAt(layoutname).GetObject(OpenMode.ForRead), Layout)
                                Dim exbtr As BlockTableRecord = DirectCast(extr.GetObject(layout.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
                                Dim objcoll As ObjectIdCollection = New ObjectIdCollection
                                For Each id As ObjectId In exbtr
                                    objcoll.Add(id)
                                Next
                                exdb.WblockCloneObjects(objcoll, btrId, New IdMapping, DuplicateRecordCloning.Ignore, False)
                            End Using
                        End Using
                        mLayoutmgr.CurrentLayout = newlayoutname
                        tr.Commit()
                        ed.Regen()
                    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.ToString & vbCr & ex.Message)
                    End Try
                End Using
            End Using
        End Sub
~'J'~
in reply to: Hallex
Hallex,
I finally got back to working on this project. I tested the code that you posted above and it works great. I had to make a couple small adjustments for 2013, but otherwise, it worked as-is.
Thanks for the help. Your code is very clear and concise.
btm
Hallex
Glad I could help,
Cheers 🙂
~'J'~
”Boost
