Hi, I would like to create a MultiLeader with block content that accesses the pre-defined block types that are available on the MLEADEREDITSTYLE window (being those Box, bubble, detail callout,etc).
The intention is then to use it and find a way to edit its text properties.
Luis Batista
Solved by LuisBatista8106. Go to Solution.
Check my response in there
http://forums.autodesk.com/t5/NET/mleader-question/td-p/2769728
~'J'~
Thanks! It works fine now.
I am not sure I understand all of the code, anyhow, I will take a deeper look into the routine since I think it still can be improved.
thks
