.NET
creating a dll file to be used by lisp and vba
1 REPLY 1
297 Views, 1 Reply
hi
i'm getting confused between a function written in vb6 and in vb.net.
i have the following code in vb6:
Public Function GroupExists(ByVal sName As String) As Boolean
Dim mgMenuGroup As AutoCAD.AcadMenuGroup
For Each mgMenuGroup In AutoCAD.Application.MenuGroups
If mgMenuGroup.Name = sName Then
GroupExists = True
Exit Function
End If
Next mgMenuGroup
GroupExists = False
End Function
and this code in vb.net (which i assume is the equivalent):
Public Function GroupExists(sGroupName As String) As Boolean
Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication = Marshal.GetActiveObject("AutoCAD.Application.16.1")
Dim mgMenuGroup As Autodesk.AutoCAD.Interop.AcadMenuGroup
For Each mgMenuGroup In AcadApp.MenuGroups
If mgMenuGroup.Name = sGroupName Then
GroupExists = True
Exit Function
End If
Next
GroupExists = False
End Function
now for my questions... is it correct that i have to set a variable to an instance of autocad (ie acadapp)??? if so does this mean everytime i need to do something with autocad (reading layers, menus etc) i have to add an instance to autocad in each of my classes, or can i add a global instance to autocad when either my lisp or vba application access my dll file??? the reason why i'm a little confused is that in vb6, there was no need to set an instance to autocad and now it seems that there is...
any help would be great
cheers
mark
1 REPLY 1
Actually, its much more than that.
For any added buttons, general watchdogging, menu control of other sorts, you use variation on applicationa and acadapp objects.
within a single drawing, and somewhat to the outside, you communicate to the workingdatabase of the app, (centered on current file) you access all and any block and hidden items within and also has methods to reach other files to grab any of the same information.
Not sure if it is general practice, but i use the implemented interface of the app to add custom buttons, placed where i like.
in non .net environments things are very different tho, such as vba that comes with autocad, you have access to the current app by default, and fairly easily just make a button that gets added like any lisp button. cui and all that.
”Boost
