.NET
Creating a block
2 REPLIES 2
809 Views, 2 Replies
Creating a block
Hi all,
I'm new to .net for autocad, but very familiar with c#. I studied some samples about creating a block from c#, but need some help figuring it out.
Waht I'm trying to do:
I have a form for some basic input. When the user presses OK the code checks if the blockname is aleady in use. When no it creates the block using following code:
private void make_block()
            double nextpoint = 0.0;
            double linedis = 7.3634;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr = new BlockTableRecord();
                btr.Name = "hoeveelheden";
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                btr.Origin = Point3d.Origin;
                btr.Units = UnitsValue.Meters;
                ObjectId btrId = bt.Add(btr);
                bt.DowngradeOpen();
                DBObjectCollection ents = new DBObjectCollection();
                //controleren op (de)markeren
                double tmp = conlengte + lengte0505 + lengte11 + lengte13 + lengte31 + lengte39 + lengte30270 + lengte93 + haailengte5050 + haailengte5070 + demconlengte +
                    demlengte0505 + demlengte11 + demlengte13 + demlengte31 + demlengte39 + demlengte30270 + demlengte93;
                if (tmp != 0.0 || pijlen != 0)
                    //(de)markeren toevoegen aan block
                    Point3d p1 = new Point3d(0.0, nextpoint, 0.0);
                    Point3d p2 = new Point3d(0.0, nextpoint + 100.0, 0.0);
                    Line ln = new Line(p1, p2);
                    ln.Layer = "wx-zwart-004";
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 100.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 100.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 90.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 90.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(7.0, nextpoint + 92.5, 0.0);
                    DBText acText = new DBText();
                    acText.SetDatabaseDefaults();
                    acText.Position = p1;
                    acText.Height = 5.0;
                    acText.TextString = "markering";
                    acText.Layer = "wx-zwart-004";
                    ents.Add(acText);
					//some more text entities are created
                    nextpoint = nextpoint + 100.0;
                //controleren op barrier
                tmp = barrier + barrier_beton + barrier_Bever + barrier_HaiSafe + barrier_Haitsma_Step + barrier_kunststof +
                    barrier_Miniguard + barrier_Romein + barrier_RWS + barrier_Safe_guard + barrier_staal + barrier_Vario_guard;
                if (tmp != 0.0 || pstuk != 0 || rimobP110s != 0 || rimobV270 != 0 || antizichtscherm != 0.0)
                    Point3d p2 = new Point3d(0.0, nextpoint + 115.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 115.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 115.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 105.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 105.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(7.0, nextpoint + 107.5, 0.0);
                    acText.TextString = "geleidebarrier";
                    ents.Add(acText);
                    if (barrier_staal != 0.0)
                        p1 = new Point3d(52.0, nextpoint + (93.5 - 1 * linedis), 0.0);
                        acText.Height = 3.5;
                        acText.TextString = Math.Round(barrier_staal, 0).ToString() + " m";
                        acText.Layer = "wx-zwart-002";
                        ents.Add(acText);
                    nextpoint = nextpoint + 115.0;
                //controleren op geleidebakens / kegels
                if (baken != 0 || kegel != 0)
                    //(geleidebakens/kegels toevoegen aan block
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 40.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 40.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(0.0, nextpoint + 30.0, 0.0);
                    p2 = new Point3d(150.0, nextpoint + 30.0, 0.0);
                    ents.Add(ln);
                    p1 = new Point3d(7.0, nextpoint + 32.5, 0.0);
                    acText.TextString = "geleidebakens / kegels";
                    ents.Add(acText);
                    nextpoint = nextpoint + 40.0;
                //controleren op verlichting
                if (lichtmast != 0 || mobilight != 0)
                    //(verlichting toevoegen aan block
                    ents.Add(ln);
                    ents.Add(ln);
                    ents.Add(ln);
                    acText.TextString = "tijdelijke verlichting";
                    ents.Add(acText);
                foreach (Entity ent in ents)
                    btr.AppendEntity(ent);
                    tr.AddNewlyCreatedDBObject(ent, true);
                tr.AddNewlyCreatedDBObject(btr, true);
                tr.Commit();
The code runs succesfully (meaning i don't get any errors), but when I want to insert the block it isn't in the list of blocks. I must be forgetting something, but am unable to figure out what.
2 REPLIES 2
DiningPhilosopher
Only skimming your code, I see nothing suspicious.
If there are other transactions being started that you don't show in your code, make sure all of them are comitted.
If your code is being called in one or more try{} blocks, make sure the catch{} blocks are not hiding an error that might also cause a transaction to abort.
in reply to: DiningPhilosopher
I went trough my code again, indeed found a transaction which I didn't dispose. Now it works just perfect. Thanks for the tip!
”Boost
