.NET
andy_pu
Message 1 of 4 (177 Views)
Create viewport in PaperSpace like a current view in Modelspace
177 Views, 3 Replies
03-04-2014 06:25 AM
Hello!!
How to setup viewport in Paperspace like a current view in Modelspace?
Thanks!!!
Valued Contributor
architectOfIdeas
Message 2 of 4 (164 Views)
Re: Create viewport in PaperSpace like a current view in Modelspace
03-04-2014 07:39 AM in reply to: andy_pu
Here's an example of how to create paperspace viewports.
Can you explain a bit more about what you mean by 'view'?
Did you simply want to show a specific object or location in the viewport? Or do you have a saved view, like one defined with the VIEW command, that you want to represent in the viewport?
andy_pu
Message 3 of 4 (142 Views)
03-04-2014 10:09 PM in reply to: architectOfIdeas
Thanks for example! By "view" I mean standart view from view manager(command "view"). I need to change view direction in current active viewport on Paperspace when I change view direction in modelspace. I change view direction in modelspace by my function so I can handle that event.
(sorry for my English)
Valued Contributor
architectOfIdeas
Message 4 of 4 (121 Views)
03-05-2014 07:52 AM in reply to: andy_pu
In the viewport class, you have a couple methods that can help you out.
If you're dealing with a standard orthographic view, you could use the Viewport.SetViewDirection method. But if you require a custom view within the viewport, you could define the custom UCS and set it using Viewport.SetUcs.
