.NET
Create Partial Menu and load C# dll.
3 REPLIES 3
2940 Views, 3 Replies
I'm using AutoCAD 2013 with C#.
I need to create a menu after Help Menu in Autocad2013.
for ex.
Top Menu Name: Thenndral
submenu1: Empty Layout
submenu2: Check ID
1. when the user click Empty Layout, then call "emptylayout.dll"
2. as well click Check ID, then call "checkid.dll"
I tried this code with the help of Kean's code. I have no problem in adding menu. but click event not working. I don't know how to add dll name in the "MenuMacro" code.
[CommandMethod("CreateMenu")]
    public void BuildMenuCUI()
      const string myCuiFile = "c:\\thenndral.cuix";
      const string myCuiFileToSend = "c:\\thenndral.cuix";
      const string myCuiSectionName = "Thenndral";
      Editor ed =
        Application.DocumentManager.MdiActiveDocument.Editor;
      string mainCui =
        Application.GetSystemVariable("MENUNAME") + ".cuix";
      CustomizationSection cs =
        new CustomizationSection(mainCui);
      PartialCuiFileCollection pcfc = cs.PartialCuiFiles;
      if (pcfc.Contains(myCuiFile))
        ed.WriteMessage("\nCustomization file \""+ myCuiFile + "\" already loaded.");
      else{
        if (System.IO.File.Exists(myCuiFile))
          ed.WriteMessage("\nCustomization file \"" + myCuiFile + "\" exists - loading it.");
          LoadMyCui(myCuiFileToSend);
        else
          ed.WriteMessage("\nCustomization file \"" + myCuiFile + "\" does not exist - building it." );
          // Create a customization section for our partial menu
          CustomizationSection pcs = new CustomizationSection();
          pcs.MenuGroupName = myCuiSectionName;
          // Let's add a menu group, with two commands
          MacroGroup mg = new MacroGroup(myCuiSectionName, pcs.MenuGroup);
          MenuMacro mm1 = new MenuMacro(mg, "Cmd 1", "^C^CCmd1", "ID_MyCmd1");
          MenuMacro mm2 = new MenuMacro(mg, "Cmd 2", "^C^CCmd2", "ID_MyCmd2");
          // Now let's add a pull-down menu, with two items
          StringCollection sc = new StringCollection();
          sc.Add("POP15");
          PopMenu pm = new PopMenu(myCuiSectionName,sc,"ID_MyPop1", pcs.MenuGroup);
          PopMenuItem pmi1 = new PopMenuItem(mm1, "Empty Layout", pm, -1);
          PopMenuItem pmi2 = new PopMenuItem(mm2, "Check ID", pm, -1);
          // Finally we save the file and load it
          pcs.SaveAs(myCuiFile);
    private void LoadMyCui(string cuiFile)
        Document doc =Application.DocumentManager.MdiActiveDocument;
        object oldCmdEcho = Application.GetSystemVariable("CMDECHO");
        object oldFileDia = Application.GetSystemVariable("FILEDIA");
        Application.SetSystemVariable("CMDECHO", 0);
        Application.SetSystemVariable("FILEDIA", 0);
        doc.SendStringToExecute("_.cuiload " + cuiFile + " ", false, false, false);
        doc.SendStringToExecute("(setvar \"FILEDIA\" " + oldFileDia.ToString()+ ")(princ) ",false, false, false);
        doc.SendStringToExecute("(setvar \"CMDECHO\" "+ oldCmdEcho.ToString()+ ")(princ) ",false, false, false);
Could you please suggest me to solve this process or other solution to create partial menu also appreciated.
Thanks in advance,
thenndral
3 REPLIES 3
Ajilal.Vijayan
Try changing this line
After NETLOAD , Your dll file name and dll command name.
new MenuMacro(mg, "Cmd 1", "^C^C._NETLOAD;MYDLL;MYCOMMAND", "ID_MyCmd1");
 Make sure the dll file path is within the autocad search path.
in reply to: Ajilal.Vijayan
Thanks Ajilal.Vijayan.
Its Works like charm.
Thanks again.
Thenndral
Ajilal.Vijayan
Thanks again.
Thenndral
You're Welcome !
”Boost
