.NET
create paper space viewport and show some model portion in view
2 REPLIES 2
spu
3393 Views, 2 Replies
We like to allow user to select a rectagular area in modal scpace. Then the code creates a paperscace viewport in a spcified layout. The viewport will show the selected area. Please find the old VBA code that achived this and the .net code I am trying with. .Net code always gives some exception.
VBA Code
 'Lets find the center of the viewport in paperspace.
    Dim center(0 To 2) As Double
    center(0) = newWidth / 2
    center(1) = newLength / 2
    center(2) = 0
    Dim lay As AcadLayout
    For Each ent In ThisDrawing.layouts
        If ent.Name = "Betsy" Then
            Set lay = ent
    Next
    ThisDrawing.ActiveLayout = lay
    ThisDrawing.ActiveSpace = acPaperSpace
    'Lets create the actual viewport
    Set newVport = ThisDrawing.PaperSpace.AddPViewport(center, newWidth, newLength)
    newVport.TrueColor = myclr
    ' Enable the viewport
    newVport.Display True
    ZoomExtents
    ' Turn on model space editing
    ThisDrawing.MSpace = True    'Here pls check
    ' Set newVport current
    ' (not always necessary but a good idea)
    ThisDrawing.ActivePViewport = newVport
    Dim ModalLeftLower(0 To 2) As Double
    Dim ModalRightUpper(0 To 2) As Double
    ModalLeftLower(0) = ModalLeftUpper(0)
    ModalLeftLower(1) = ModalRightBottom(1)
    ModalLeftLower(2) = 0
    ModalRightUpper(0) = ModalRightBottom(0)
    ModalRightUpper(1) = ModalLeftUpper(1)
    ModalRightUpper(2) = 0
    ' Zoom window in model space
    ZoomWindow ModalLeftLower, ModalRightUpper
    ' Turn model space editing off
    ThisDrawing.MSpace = False
More code
.Net Code
 Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
      Autodesk.AutoCAD.DatabaseServices.Database db = doc.Database;
      Autodesk.AutoCAD.EditorInput.Editor ed = doc.Editor;
      // We're accessing drawing objects, so we need a transaction
      using (Autodesk.AutoCAD.DatabaseServices.Transaction tr = db.TransactionManager.StartTransaction())
        // Get the primary paperspace from the block table
        Autodesk.AutoCAD.DatabaseServices.BlockTable bt =  (Autodesk.AutoCAD.DatabaseServices.BlockTable)tr.GetObject(db.BlockTableId,Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead);
        Autodesk.AutoCAD.DatabaseServices.BlockTableRecord ps =(Autodesk.AutoCAD.DatabaseServices.BlockTableRecord)tr.GetObject(bt[Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.PaperSpace], Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite);
         // Create a variety of objects for our clip boundaries
           //Autodesk.AutoCAD.DatabaseServices.DBObjectCollection objs = new Autodesk.AutoCAD.DatabaseServices.DBObjectCollection();
           // Create our viewport, adding that also
           SwitchTo("Betsy");
           Autodesk.AutoCAD.DatabaseServices.Viewport vp = new Autodesk.AutoCAD.DatabaseServices.Viewport();
           vp.SetDatabaseDefaults();
           vp.CenterPoint = new Autodesk.AutoCAD.Geometry.Point3d(newWidth/2, newLength/2, 0);
           vp.Width = newWidth;
           vp.Height = newLength;
            ps.AppendEntity(vp);
            tr.AddNewlyCreatedDBObject(vp, true);
            doc.Editor.SwitchToPaperSpace();
           //vp.ViewDirection = new Autodesk.AutoCAD.Geometry.Vector3d(1, 1, 1);
          //  vp.On = true;
            // Set the new viewport current via an imported ObjectARX function
          //  acedSetCurrentVPort(vp.UnmanagedObject);
            doc.Editor.SwitchToModelSpace();
          //  tr.Commit();
           Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(ModalLeftUpper.X, ModalRightBottom.Y, 0);
              Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(ModalRightBottom.X, ModalLeftUpper.Y, 0);
             Zoom.ZoomWindow(ptll, ptur);
            //Autodesk.AutoCAD.Geometry.Point3d ptll = new Autodesk.AutoCAD.Geometry.Point3d(0, 0, 0);
            //Autodesk.AutoCAD.Geometry.Point3d ptur = new Autodesk.AutoCAD.Geometry.Point3d(100, 100, 0);
            //Autodesk.AutoCAD.Interop.AcadApplication pApp;
            //pApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
            //pApp.ZoomWindow(ptll.ToArray(), ptur.ToArray());
             tr.Commit();
Shijith
2 REPLIES 2
Balaji_Ram
in reply to: spu
Hi Shijith,
I dont have a ready code to do exactly the same steps.
But here is a Devblog post that can give you a start.
http://adndevblog.typepad.com/autocad/2012/08/changing-zoom-in-paperspace-viewport.html
It sets the paperspace viewport parameters based on the database extents. You can modify it to set the viewport parameters based on any other rectangle corner points. In the sample code from the blog post, the "x_Min" and "x_Max" are the database extent points but in your case it will represent the extents of the selected rectangle in model space.
This will allow you to set the paperspace viewport to show the model within the selected rectangle.
Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
spu
in reply to: Balaji_Ram
Thanks Balaji. It worked like a charm....
Shijith
”Boost
