I have opened a document with several xref and i want to add new entityes into those xref. How can i do?
We launch _refedit/_refclose commands in AutoCad Command line for this. I want to do the same in Autocad.NET
Ane
Solved by Virupaksha_aithal. Go to Solution.
I think the new blog http://adndevblog.typepad.com/autocad/2013/10/in-place-edit-of-external-reference-drawing-files.html should provide you the hints in editing the external reference drawing file.
