.NET
Create layer programmatically
11 REPLIES 11
Message 1 of 12
fmarcelino
805 Views, 11 Replies
i'm trying to create a layer programmatically with the following code:
< CommandMethod("addlayer") > _
Public Function AddLayer()
Dim curdb As Database
Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager
Dim myT As Transaction
curdb = Application.DocumentManager.MdiActiveDocument.Database
tm = curdb.TransactionManager
myT = tm.StartTransaction()
Dim lt As LayerTable = CType(tm.GetObject(curdb.LayerTableId, OpenMode.ForWrite), LayerTable)
Dim x As New LayerTableRecord
x.Name = "Test1"
x.IsOff = chkON.Checked 'Checkbox
x.IsFrozen = chkFrozen.Checked 'Checkbox
x.IsLocked = chkLocked.Checked 'Checkbox
'Color RED
x.Color = Autodesk.AutoCAD.Colors.Color.FromRgb(255, 0, 0)
'Lineweight
x.LineWeight = LineWeight.LineWeight120
x.IsPlottable = chkPlottable.Checked 'Checkbox
x.Description = "Layer test1"
lt.Add(x)
myT.Commit()
End Function
This code actually inserts the layer, but first, the property 'DESCRIPTION' appears empty. Second, after I run this code the layer is inserted but, if I access the layer manager just to check if the layer were actually inserted and then click cancel, the insert layer gets removed!! I don't understand why. Maybe because the document database isn't updated automatically...I don't know.
Thanks in advance for your attention, I hope you can help me.
Filipe Marcelino
11 REPLIES 11
Message 2 of 12
wesbird
in reply to: fmarcelino
add myT.AddNewlyCreatedDBObject before Commit.
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Message 3 of 12
fmarcelino
like this?
finally
myT.AddNewlyCreatedDBObject(x, True) 'LayerTableRecord
myT.Commit()
end try
or
finally
myT.AddNewlyCreatedDBObject(lt, True) 'LayerTable
myT.Commit()
end try
Filipe Marcelino
Message 4 of 12
wesbird
Message 5 of 12
fmarcelino
Thanks weslleywang, it worked. My command ended like this:
' Define command 'addlayer'
x.Name = "Test Layer"
x.IsOff = True
x.IsFrozen = True
x.IsLocked = True
'Color RED
x.IsPlottable = False
x.Description = "Layer insert sucessfully"
lt.Add(x)
myT.Commit()
End Function
Filipe Marcelino null
Message 6 of 12
cgay
First, I think your "Function" should be "Shared Sub".
Second, you probably should wrap your transaction in an error handler.
Third, you should only "Commit" the transaction if there were no errors, otherwise, you should "Abort" the transaction.
Attached is your code with error handling.
Message 7 of 12
Dave Jameson
Hi.
This code is great, but could somebody please show me how to add a linetype to this layer!!!
I am using vb.net 2003 and autocad 2006.
yours in anticipation
Dave
Message 8 of 12
First search the curdb.LinetypeTableId.
Search for the linetype you want in Linetypetable and fetch the LinetypeID in the variable MyLinetypeObjectID
Finally add code in the part with x ...:
.LinetypeObjectId = MyLinetypeObjectID
Message 9 of 12
parcea89
I hope this can help.....
Auto Layer Loading, just replace FUNCTIONNAME to your desire descipline like "Archi, Civil or Struct.
;;;=== Make Layer =================================
(DEFUN C:FUNTIONNAME ()
(COMMAND "LAYER" "MakeLayer" " "LeyerName" "Color" "Red" "" "LineType" "center" ""
"SET" "0" "")
(PRINC)
(PROMPT "\nFuntionName LAYERS LOADED......")
(PRINC)
HERE ARE THE SAMPLE
(DEFUN C:ARCHI ()
(COMMAND "LAYER"
"M" " "Wall" "C" "Green" "" "LT" "Continuous" ""
"M" " "Window" "C" "11" "" "LT" "Hidden" ""
"SET" "0" "")
(PRINC)
(PROMPT "\nARCHITECTURAL LAYERS LOADED......")
(PRINC)
Message 10 of 12
Dave Jameson
Thanks Manfred
I had the x.LinetypeObjectId = MyLinetypeObjectID part but i am strugeling with the search of the linetype table I have:-
Dim MyLinetypeObjectID as LinetypeId = curdb.LinetypeTableId.
but can't see the way forward.
All help much appreciated.
Regards
Dave
Message 11 of 12
Dave Jameson
Thanks 'parcea'
I have a lisp version already but here is something you could add to yours to place a description in your layer definition.
;;;*Syntax (ldescription name desc)
(DEFUN ldescription(LAYERNAME LAYERDESC)
(setq myLayer (vla-Add (vla-Get-Layers (vla-Get-ActiveDocument
(vlax-Get-Acad-Object))) LAYERNAME))
(vla-Put-Description myLayer LAYERDESC)
Regards
Dave
Message 12 of 12
mgsell
Filipe can you tell me what refernce need to be checked to use the autodesk.autocad.databseservices ? thanks
”Boost
