.NET
Active Member
Barabasishe
Message 1 of 6 (499 Views)
create drawing from template dwt
499 Views, 5 Replies
11-13-2012 07:25 PM
Hi!
I want to open dwg from template:
   DocumentCollection acDocMgr = Application.DocumentManager;
   Document acDoc;
   try
              acDoc = acDocMgr.Add(FileNameTemplate);
      acDocMgr.MdiActiveDocument = acDoc
   catch
But on the line "acDocMgr.MdiActiveDocument = acDoc" AutoCAD is hanging and in around 10 sec AutoCAD closes.
How does the new document from template set active (do current)?
Yeah, it works good. Thanks. It is done this way:
        [CommandMethod("calc", CommandFlags.Session)]
        public void doIt()
           openFromTemplate();
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            // my calculation
        [CommandMethod("opdwt", CommandFlags.Session)]
        public void openFromTemplate()
            DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            try
                using (DocumentLock doclock = doc.LockDocument())
                    string tmpPath = "my template file dwt";
                    Document newdoc = dm.Add(tmpPath);
                    Database newdb = newdoc.Database;
                    using (DocumentLock newdoclock = newdoc.LockDocument())
                        using (Transaction newtr = newdoc.TransactionManager.StartTransaction())
                            dm.MdiActiveDocument = newdoc;
            catch {}
Hallex
Message 2 of 6 (481 Views)
Re: create drawing from template dwt
11-14-2012 02:24 AM in reply to: Barabasishe
You have to use CommandFlags.Seesion and also
use LockDocument
Here is a quick sample:
        public void testOpenFromTemplate()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                    string tmpPath = "acad.dwt";
                    //change file name to save:
                    string fn = @"C:\Test\FromTemplate.dwg";
                            Editor newed = newdoc.Editor;
                            Point3d pt = newed.GetPoint("\nPick point: ").Value;
                            Line ln = new Line(pt, db.Extmax);
                            ln.ColorIndex = 1;
                            BlockTableRecord newbtr = (BlockTableRecord)newtr.GetObject(newdb.CurrentSpaceId, OpenMode.ForWrite);
                            newbtr.AppendEntity(ln);
                            newtr.AddNewlyCreatedDBObject(ln, true);
                            newtr.Commit();
                            MessageBox.Show("Saved as: " + fn);
                    newdoc.CloseAndSave(fn);
                    // just to work further if you wanted be:
                    dm.Open(fn, false);
                    MessageBox.Show("You can try to do your rest job here");
                doc.CloseAndDiscard();
            catch (System.Exception ex)
                MessageBox.Show(ex.Message + "\n" + ex.StackTrace);
            finally
                // do nothing
Active Member
Barabasishe
Message 3 of 6 (468 Views)
11-14-2012 07:49 PM in reply to: Hallex
        public void doIt()
           openFromTemplate();
            // my calculation
            try
            catch {}
Hallex
Message 4 of 6 (460 Views)
11-15-2012 12:22 AM in reply to: Barabasishe
Glad you get it worked, just one note though:
Don't use empty code block for CATCH statement,
better yet to display an error message in case you
have got it,
Cheers :smileyhappy:
Active Member
Barabasishe
Message 5 of 6 (403 Views)
11-26-2012 12:38 AM in reply to: Hallex
But it's not work for one situation.
In main function i call two methods - 1. load dwg through method readdwgfile 2. create drawing from template
In order to the second func works i add this expression above the main func
[CommandMethod("testSituation", CommandFlags.Session)]
But now the first method (readDwgFile) give me error - eNotOpenForWrite. If i remove this expression, the first method can work and the second won't work.
Test code:
        public void testSit()
            Database database = loadDWG(@"C:\...\myfile.dwg");
            openDrawingFromTemplate(@"\\tn...\A2_P.dwt");
public Database loadDWG(string PathDWG)
            Database newDWG = new Database(false, true);
            if (System.IO.File.Exists(PathDWG))
                try
                    newDWG.ReadDwgFile(PathDWG, FileOpenMode.OpenTryForReadShare, true, "");
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    System.Windows.Forms.MessageBox.Show(ex.Message, "Error");
                return newDWG;
            else
                System.Windows.Forms.MessageBox.Show(String.Format("File {0} is not exist", PathDWG), "Error");
                return null;
Is such way exist which can help to solve this situation?
Active Member
Barabasishe
Message 6 of 6 (399 Views)
11-26-2012 01:07 AM in reply to: Barabasishe
May be there are such flags which can help to work both methods?
