.NET
create drawing from template dwt
5 REPLIES 5
1280 Views, 5 Replies
Hi!
I want to open dwg from template:
   DocumentCollection acDocMgr = Application.DocumentManager;
   Document acDoc;
   try
              acDoc = acDocMgr.Add(FileNameTemplate);
      acDocMgr.MdiActiveDocument = acDoc
   catch
But on the line "acDocMgr.MdiActiveDocument = acDoc" AutoCAD is hanging and in around 10 sec AutoCAD closes.
How does the new document from template set active (do current)?
5 REPLIES 5
Hallex
You have to use CommandFlags.Seesion and also
use LockDocument
Here is a quick sample:
       [CommandMethod("opdwt", CommandFlags.Session)]
        public void testOpenFromTemplate()
            DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            try
                using (DocumentLock doclock = doc.LockDocument())
                    string tmpPath = "acad.dwt";
                    //change file name to save:
                    string fn = @"C:\Test\FromTemplate.dwg";
                    Document newdoc = dm.Add(tmpPath);
                    Database newdb = newdoc.Database;
                    using (DocumentLock newdoclock = newdoc.LockDocument())
                        using (Transaction newtr = newdoc.TransactionManager.StartTransaction())
                            dm.MdiActiveDocument = newdoc;
                            Editor newed = newdoc.Editor;
                            Point3d pt = newed.GetPoint("\nPick point: ").Value;
                            Line ln = new Line(pt, db.Extmax);
                            ln.ColorIndex = 1;
                            BlockTableRecord newbtr = (BlockTableRecord)newtr.GetObject(newdb.CurrentSpaceId, OpenMode.ForWrite);
                            newbtr.AppendEntity(ln);
                            newtr.AddNewlyCreatedDBObject(ln, true);
                            newtr.Commit();
                            MessageBox.Show("Saved as: " + fn);
                    newdoc.CloseAndSave(fn);
                    // just to work further if you wanted be:
                    dm.Open(fn, false);
                    MessageBox.Show("You can try to do your rest job here");
                doc.CloseAndDiscard();
            catch (System.Exception ex)
                MessageBox.Show(ex.Message + "\n" + ex.StackTrace);
            finally
                // do nothing
in reply to: Hallex
Yeah, it works good. Thanks. It is done this way:
        [CommandMethod("calc", CommandFlags.Session)]
        public void doIt()
           openFromTemplate();
            // my calculation
        public void openFromTemplate()
            try
                    string tmpPath = "my template file dwt";
            catch {}
Hallex
Glad you get it worked, just one note though:
Don't use empty code block for CATCH statement,
better yet to display an error message in case you
have got it,
Cheers Smiley Happy
in reply to: Hallex
But it's not work for one situation.
In main function i call two methods - 1. load dwg through method readdwgfile 2. create drawing from template
In order to the second func works i add this expression above the main func
[CommandMethod("testSituation", CommandFlags.Session)]
But now the first method (readDwgFile) give me error - eNotOpenForWrite. If i remove this expression, the first method can work and the second won't work.
Test code:
        public void testSit()
            Database database = loadDWG(@"C:\...\myfile.dwg");
            openDrawingFromTemplate(@"\\tn...\A2_P.dwt");
public Database loadDWG(string PathDWG)
            Database newDWG = new Database(false, true);
            if (System.IO.File.Exists(PathDWG))
                try
                    newDWG.ReadDwgFile(PathDWG, FileOpenMode.OpenTryForReadShare, true, "");
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    System.Windows.Forms.MessageBox.Show(ex.Message, "Error");
                return newDWG;
            else
                System.Windows.Forms.MessageBox.Show(String.Format("File {0} is not exist", PathDWG), "Error");
                return null;
Is such way exist which can help to solve this situation?
May be there are such flags which can help to work both methods?
”Boost
