.NET
Create database resident system variable
6 REPLIES 6
658 Views, 6 Replies
Is it possible to create a database resident system variable? My desire is to create a system variable that I can use to expose results of my program, and/or let the user set values that the program can use. I thought I saw an example somewhere, but I can't seem to find it now.
Any Ideas?
HomeBoy Out
6 REPLIES 6
No way to create your own system variables.
You can store data in dictionaries and provide your own UI or command to let
the user view or change them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6166438@discussion.autodesk.com...
example somewhere, but I can't seem to find it now. Any Ideas? Thanks
HomeBoy Out
NathTay
See AutoCAD help for info on USERI1-5 & USERR1-5 system variables. Obvious shortcomings are limited number of variables and knowing they aren't/won't be used by another person/program.
Or.... P/Invoke:
 acedGetEnv and acedSetEnv
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<HomeBoyLV>
now. Any Ideas? Thanks HomeBoy Out
I think you're confusing storing data in a DWG file with
storing it in the registry.
wrote in message news:6166949@discussion.autodesk.com...
Or.... P/Invoke:
HomeBoy Out
Thanks Tony and yes,
Please ignore what I just previously posted 🙂
"Tony Tanzillo"
Artvegas
Very old post, but from AutoCAD 2011 onwards it is possible to create a custom system variable by adding a key to the registry.
Your user might need elevated UAC permissions to be able to add it to the registry's local-machine hive, but this can be achieved by your installer.
There's more information contained at the bottom of the following through-the-interface post for those who are interested Custom System Variable Link
Art
”Boost
