.NET
matinau
Message 1 of 4 (322 Views)
Create a workspace from an existing workspace .NET
322 Views, 3 Replies
03-05-2013 11:22 PM
Hi I'm trying to create / copy an existing workspace using c#
I couldn't find a direct way to just copy the existing workspace so I tried to add it's properties manually. The only trouble is I can't seem to cover all the settings here's what I have so far... any help would be much appreciated.
var userworkspace = new Workspace(cs, acadUser)
  WorkspaceRibbonRoot = wsMaster.WorkspaceRibbonRoot,
  WorkspaceQuickAccessToolbar = wsMaster.WorkspaceQuickAccessToolbar,
  Name = acadUser
foreach (WorkspaceToolbar wst in wsMaster.WorkspaceToolbars)
 userworkspace.WorkspaceToolbars.Add(wst);
foreach (WorkspacePopMenu wsp in wsMaster.WorkspacePopMenus)
 userworkspace.WorkspacePopMenus.Add(wsp);
Pretty basic I know, how can I get PartialCUI tabs, palettes, etc.. applied?
Cheers
Thanks for the reply, unfortunately I needed to reload the main cui file not a partial cui. The following actually worked?
Application.LoadMainMenu(csMain.CUIFileName);
since there was no "UnloadMainMenu" I called the above code whilst the main cui was loaded which seemed to work? The only annoyance been the number of times the environment reloaded.
1st - on initial load
2nd - on "LoadMainMenu"
3rd - on "SetcurrentWorkspace"
Can you think of a better / alternative way other than sendstringcommand? Will this approach cause problems since the main cui was never unloaded.
If not I'll run with this, thanks
matinau
Message 2 of 4 (291 Views)
Re: Create a workspace from an existing workspace .NET
03-06-2013 09:29 PM in reply to: matinau
Ok so I figured out how to create my new workspace from an existing workspace... pretty much what I had previously. The only trouble now is that the newly created workspace isn't full recognised i.e. I can't set it current unless I do it through the cui editor or restart CAD?
How do I properly update?
Thanks in advance, Matt
Moderator
Alexander.Rivilis
Message 3 of 4 (287 Views)
03-06-2013 10:36 PM in reply to: matinau
It is look like you have to unload/load cui(x)-file with help of Application.UnloadPartialMenu/Application.LoadPartialMenu and set WORKSPACE system variable with help of Application.SetSystemVariable
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
matinau
Message 4 of 4 (274 Views)
03-07-2013 02:07 PM in reply to: Alexander.Rivilis
