.NET
Create a Ribbon Control Combo Box with Directory list
4 REPLIES 4
cam-nav
1734 Views, 4 Replies
I would like to create my own Ribbon Control for a custom cui with a combo box that fills in the appropriate directory of scripts.
I will also need a button to execute this script from my combo box that will pass (executescript"my script.scr")
I have Visual C# 2008 Express
I am just starting to look at C# code and have no idea how to start this process.
If anyone is generous enough to do a little hand holding for a bit I appreciate it very much.
Dave
4 REPLIES 4
StephenPreston
in reply to: cam-nav
To create custom ribbon controls you'll need to use WPF. There are a few WPF presentations in our webcast archive here - http://www.adskconsulting.com/adn/cs/api_course_webcast_archive.php
Cheers,
Stephen Preston
Autodesk Developer Network
Edited by
Discussion_Admin
Cheers,
Stephen Preston
cam-nav
Thanks Stephen but the link does not work.
I figured it out, you have an extra period in the link.
Thanks for the heads up I will look into this....
cam-nav
The above link is broken now, it used to work but I think it's from the Autodesk site restructure.
Balaji_Ram
The webcasts can also be downloaded from here :
http://adndevblog.typepad.com/autocad/2013/05/api-webcast-archive.html
Balaji
Developer Technical Services
”Boost
