.NET
Active Contributor
btmcad
Message 1 of 6 (1,697 Views)
create a bitmap file from the current dwg
1697 Views, 5 Replies
12-03-2012 11:10 AM
I'm working on a VB.NET program that resizes the current drawing window and creates a bitmap file.
Currently, I can get the window to resize to the correct length and width. However, I'm lost as far as creating a bitmap. I found some code in C# on the Through the Interface site:
http://through-the-interface.typepad.com/through_the_interface/2009/09/taking-screenshots-of-autocad...
Unfortunately, I'm not that familiar with C# and can't get the code to work if I try to convert to VB.net.
Any help would be greatly appreciated.
Ultimately, I want to then convert the bmp file to a gif with a transparent background. I know how to convert a bmp to gif, but is it possible to programmatically convert it to a transparent background?
btm
Contributor ow
ow
Message 2 of 6 (1,678 Views)
Re: create a bitmap file from the current dwg
12-03-2012 02:10 PM in reply to: btmcad
You can use the BMPOUT command. (Or PNGOUT).
ow
Valued Mentor
gasty1001
Message 3 of 6 (1,659 Views)
12-03-2012 06:43 PM in reply to: btmcad
You can use an online service to translate from C# to VB, like this DevFusion, using that, the code from Kean blog translate to this:
Imports acApp = Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports System.Drawing.Imaging
Namespace ScreenshotTest
	Public Class Commands
		<CommandMethod("CSS")> _
		Public Shared Sub CaptureScreenShot()
			ScreenShotToFile(acApp.Application.MainWindow, "c:\main-window.png", 0, 0, 0, 0)
			ScreenShotToFile(acApp.Application.DocumentManager.MdiActiveDocument.Window, "c:\doc-window.png", 30, 26, 10, 10)
		End Sub
		Private Shared Sub ScreenShotToFile(wd As Autodesk.AutoCAD.Windows.Window, filename As String, top As Integer, bottom As Integer, left As Integer, right As Integer)
			Dim pt As Point = wd.Location
			Dim sz As Size = wd.Size
			pt.X += left
			pt.Y += top
			sz.Height -= top + bottom
			sz.Width -= left + right
			' Set the bitmap object to the size of the screen
			Dim bmp As New Bitmap(sz.Width, sz.Height, PixelFormat.Format32bppArgb)
			Using bmp
				' Create a graphics object from the bitmap
				Using gfx As Graphics = Graphics.FromImage(bmp)
					' Take a screenshot of our window
					gfx.CopyFromScreen(pt.X, pt.Y, 0, 0, sz, CopyPixelOperation.SourceCopy)
					' Save the screenshot to the specified location
					bmp.Save(filename, ImageFormat.Png)
				End Using
			End Using
		End Sub
	End Class
End Namespace
As for a GIF file with a transparency color, you can do it using GDI+ and setting the Alfa of the selected color to 0 in the palette of the GIF, remember that GIF file have a palette with the colors (max 256) to display.
Gaston Nunez
Active Contributor
btmcad
Message 4 of 6 (1,643 Views)
12-03-2012 08:12 PM in reply to: gasty1001
Thank you Gaston,
I didn't explain clearly in my original post, but the bmp will be created from a selection set. I'm not sure how I can use that code with a selection set.
Here's my code. I commented where I need to create the bmp. This can be done with COM, however, I would prefer to figure out how to do it with .net code.
 Public Sub Main()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
            Dim ed As Editor = doc.Editor
            Dim docWindow As Window = doc.Window
            docWindow.WindowState = Window.State.Normal
            Dim size As System.Drawing.Size = docWindow.GetSize
            ed.WriteMessage(vbCrLf + "Document Size:" + vbCrLf + size.ToString() + vbCrLf)
            Dim newSize As System.Drawing.Size = New System.Drawing.Size(950, 573) 'was 608
            docWindow.SetSize(newSize)
            ZoomExtents()
            '' Select objects in the drawing area
            Dim ssPrompt As PromptSelectionResult = ed.GetSelection()
            '' If the prompt status is OK, objects were selected
            If ssPrompt.Status = PromptStatus.OK Then
                Dim acSSet As SelectionSet = ssPrompt.Value
                'This is where I want to export the selection set to a bmp file
            End If
Valued Mentor
gasty1001
Message 5 of 6 (1,639 Views)
12-03-2012 09:52 PM in reply to: btmcad
What about of using the plotting API to export the zoomed area to a bitmap file?, you have to use the appropriate pc3 configuration file (Publish to Web JPG/PNG.pc3  or create a new one in the plotter manager).
Gaston Nunez
Contributor ow
ow
Message 6 of 6 (1,630 Views)
12-03-2012 10:56 PM in reply to: btmcad
The BMPOUT command does accept a selection set, but you would probably need to pInvoke acedCommand from objectArx c++ in order initialize it properly. (I'm using it from C++).
Otherwise, Keans' code should work just fine, just set visibility false or turn off unwanted layers on whatever you don't want to display in the image, and restore it afterwards.
ow
