.NET
Create 3dPolyLine
9 REPLIES 9
Message 1 of 10
488 Views, 9 Replies
Create 3dPolyLine
Hi, all.
I intend to do my code about 3dOffset.
First of all, creating 3dPolyLine is the big problem for me.
I couldn't find any example about creating 3dPolyLine.
Help me,plz.
Thanks in advance.
9 REPLIES 9
Message 2 of 10
http://discussion.autodesk.com/thread.jspa?messageID=5315082
wrote in message news:5464486@discussion.autodesk.com...
Hi, all.
Help me,plz.
Thanks in advance.
Message 3 of 10
Thank you,Paul.
Is it possible to get whole example code?
Thank you again.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class GILSclass1
_
Public Sub Create3dPoly()
Dim pts As Point3dCollection = New Point3dCollection
Dim ptsArr As Double() = {0, 0, 0, 10, 10, 10, 0, 10, 10}
Dim i As Integer = 0
While i < ptsArr.Length
pts.Add(New Point3d(ptsArr(i), ptsArr(i + 1), ptsArr(i + 2)))
i = i + 3
End While
End Sub
End Class
Message 4 of 10
What else do you need? Add the entity to the
database the same way you would for other
other entities. How do you add a line?
wrote in message news:5464633@discussion.autodesk.com...
Thank you,Paul.
Thank you again.
_
i = i + 3
End While
End Sub
End Class
Message 5 of 10
Finally, I made the code.
But, Error occured.
How in the world,should I repair the following code?
It's too difficult to get correct code. Help me,plz.
_
Dim my3dpoly As Polyline3d = New Polyline3d(Poly3dType.SimplePoly, pts, False)
i = i + 3
End While
Draw3dPoly(my3dPoly)
End Sub
Friend Function Draw3dPoly(ByVal my3dPoly As Polyline3d) As ObjectId
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim transMgr As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
Dim trans As Transaction = transMgr.StartTransaction
Try
Dim btr As BlockTableRecord = CType(trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
btr.AppendEntity(my3dPoly)
trans.AddNewlyCreatedDBObject(my3dPoly, True)
trans.Commit()
Catch ex As Autodesk.AutoCAD.Runtime.Exception
ed.WriteMessage("Error Message: " + ex.Message)
Finally
If Not (my3dPoly Is Nothing) Then
my3dPoly.Dispose()
End If
End Try
Return my3dPoly.ObjectId
End Function
End Class
Message 6 of 10
In your main function you're adding your polyline before pts has any data.
In your draw function you're disposing of your object if its true and then
trying to get its ID...boom!
If my3dPloy = nothing is false then
Not m3dpoly = nothing is true...
wrote in message news:5465999@discussion.autodesk.com...
But, Error occured.
_
pts, False)
i = i + 3
End While
End Sub
Dim ed As Editor =
Try
BlockTableRecord)
trans.Commit()
Finally
my3dPoly.Dispose()
End If
End Try
End Function
End Class
Message 7 of 10
Thank you for your reply.
Not yet,error occurs.
Plz,check my attached code and give me a piece of advice.
Message 8 of 10
[code]
Public Sub Draw3DPoly()
Dim db As Database = HostApplicationServices.WorkingDatabase()
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Try
Dim bt As BlockTable = tr.GetObject(db.BlockTableId,
OpenMode.ForRead)
tr.GetObject(bt(BlockTableRecord.ModelSpace), _
OpenMode.ForWrite)
i = i + 3
End While
pts, False)
btr.AppendEntity(my3dpoly)
tr.AddNewlyCreatedDBObject(my3dpoly, True)
tr.Commit()
Catch
Finally
tr.Dispose()
End Try
End Sub
[/code]
wrote in message news:5466362@discussion.autodesk.com...
Message 9 of 10
How happy I am! Pardon my ignorance.
Thank you so much.
I appreciate for your kindness and effort.
Message 10 of 10
You're welcome. You may want to download the
labs here - save yourself some time.
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
wrote in message news:5466387@discussion.autodesk.com...
Thank you so much.
”Boost
