.NET
.NET
Member
0 Kudos
Post 1 of 7
Crash when Transaction takes too long
496 Views, 6 Replies
07-24-2012 11:36 PM
Hello everyone,
i have got a problem with AutoCAD 2010 right now. Im having some procedures that take very long to process in between a TransactionManager.StartTransaction and Commit/Abort.
When taking too long AutoCAD sometimes just disappears/crashes without giving a call stack/Exception or anything. There are also no memory leaks or exceptions raised, though i send some status messages to the command line of AutoCAD.
Does AutoCAD need anything like a KeepAlive? Do i have to send it some specific messages or anything? Is that a common problem?
Distinguished Mentor
91 Kudos
Post 2 of 7
Re: Crash when Transaction takes too long
07-25-2012 06:52 AM in reply to: OrgadataPST
Please show the code, and any other relevant information like platform, VS version, .NET Framework, drawing size (posting a sample dwg is very useful) , etc.
Gaston Nunez
Member
0 Kudos
Post 3 of 7
07-25-2012 07:19 AM in reply to: gasty1001
Sadly i can not provide the drawing, because it crashes where the drawing gets generated.
VS-Version: 2008 C# Standard
.NET: 3.5
And here is the C# code(modified though):
using (Transaction acTransaction = TransactionManager.StartTransaction())
                try
                    CurrentTransaction = acTransaction;
                    BlockTableRecord acBlockTableRecord = acTransaction.GetObject(BlockIds.Peek(),
                            OpenMode.ForWrite) as BlockTableRecord;
                    // Create a new object
                    Region acRegion = GetProfileRegion(profile);
                    Polyline3d acPath = GetExtrusionPath(profile.Axis);
                    Solid3d acSolid = new Solid3d();
                    acSolid.SetDatabaseDefaults();
                    acSolid.ExtrudeAlongPath(acRegion, acPath, 0);
                    Solid3d acSlicedSolid = acSolid;
                    try
                        SolidAnalyzer.GetFaceNormals(profile, acSolid);
                    finally
                        if (acSlicedSolid != null)
                            acSlicedSolid.Color = Autodesk.AutoCAD.Colors.Color.FromColor(profile.OuterColor);
                    // Append the newly created object to model space and active transaction
                    acBlockTableRecord.AppendEntity(acSlicedSolid);
                    acTransaction.AddNewlyCreatedDBObject(acSlicedSolid, true);
                    acRegion.Dispose();
                    acPath.Erase();
                    // Save changes to database and close transaction
                    acTransaction.Commit();
                    AutoCADApplication.Print("Profile: " + profile.Name + " successfully constructed.");
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    AutoCADApplication.Print("Failed to construct profile " + profile.Name
                        + "\n" + ex.Message + "\n\n" + ex.StackTrace);
                    acTransaction.Abort();
                finally
                    CurrentTransaction = null;
The GetProfileRegion and GetExtrusionPath Methods always work/never crashed before and i can´t post them for different reasons. The profile region is a highly detailed cut of a window profile.
The SolidAnalyzer class is defined as follows:
public static class SolidAnalyzer
        private static string Vector3dToString(Vector3d vector)
            return "[" +
                vector.X.ToString("F2") + ", " +
                vector.Y.ToString("F2") + ", " +
                vector.Z.ToString("F2")
        private static Vector3d GetFaceNormal(Autodesk.AutoCAD.BoundaryRepresentation.Face face, Point3d point)
            PointOnSurface ptOnSurf = face.Surface.GetClosestPointTo(point);
            Point2d param = ptOnSurf.Parameter;
            Vector3d normal = ptOnSurf.GetNormal(param);
            Vector3d normalTest = normal.MultiplyBy(1E-6 / normal.Length);
            Point3d ptTest = point.Add(normalTest);
            PointContainment ptContainment = new PointContainment();
            bool reverse = false;
            using(BrepEntity brepEnt = face.Brep.GetPointContainment(ptTest, out ptContainment))
                if(ptContainment != PointContainment.Outside)
                    reverse = true;
            return normal.MultiplyBy(reverse ? -1.0 : 1.0);
        public static List<Vector3d> GetFaceNormals(Profile profile, Solid3d profileSolid)
            List<Vector3d> faceNormals = new List<Vector3d>();
            using (Brep brep = new Brep(profileSolid))
                foreach (Autodesk.AutoCAD.BoundaryRepresentation.Face face in brep.Faces)
                    using (BrepEntity brepEnt = face.GetPointContainment(new Point3d(0, 0, 0), out ptContainment))
                        faceNormals.Add(GetFaceNormal(face, new Point3d(0, 0, 0)));
                        //if (ptContainment == PointContainment.Inside ||
                        //    ptContainment == PointContainment.OnBoundary)
                            AutoCADApplication.Print("\nFace Normal at " +
                                "[0, 0, 0] = " + Vector3dToString(GetFaceNormal(face, new Point3d(0, 0, 0))));
            return faceNormals;
After adding the SolidAnalyzer class and using GetFaceNormals AutoCAD sometimes first freezes/does not respond and then crashes or disappears after some normals have been written to the commandline.
 This procedure takes very long because the solid3d has >300 faces most of the time.
ADN Support Specialist
27 Kudos
Post 4 of 7
07-30-2012 04:14 PM in reply to: OrgadataPST
I have not run your code to test what's going on exactly, but i can guess just looking... Please see my comments below...
    try
        // Fenton : you must dispose all AutoCAD objects before
        // this function goes out of scope, use using. Otherwise those objects will be disposed by the GC on a worker thread, which will most likely crash AutoCAD
        using (Region acRegion = GetProfileRegion(profile))
          using (Polyline3d acPath = GetExtrusionPath(profile.Axis))
            using (Solid3d acSolid = new Solid3d())
              // Fenton: what does this line mean? if you are trying
              // to make a copy, think again because it won't
              //Solid3d acSlicedSolid = acSolid;
              // Fenton: this is better
              Solid3d acSlicedSolid = new Solid3d();
              acSlicedSolid.CopyFrom(acSolid);
              try
              finally
              acPath.Erase();
    finally
Fenton Webb
Developer Technical Services
Autodesk Developer Network
27 Kudos
Post 5 of 7
07-30-2012 04:30 PM in reply to: fenton.webb
I also just posted this for you guys...
http://adndevblog.typepad.com/autocad/2012/07/forcing-the-gc-to-run-on-the-main-thread.html
Fenton Webb
Member
0 Kudos
Post 6 of 7
07-31-2012 12:12 AM in reply to: fenton.webb
Thanks, Fenton.
The line where it says acSlicedSolid= ... was just a remain of a slicing procedure i commented out to test, sadly i forgot that line. It wasn´t intended to copy anything, it´s not a struct. Was used to determine which Solid3d to be cut because it was cut multiple times and that one was just a pointer to it.
Anyways, the GC won´t collect them in this case cause the objects are still referenced and using "using" doesn´t solve it either. I´ve just splitted it into multiple small transactions now and somehow it works.
I can´t really tell why though..., thanks a lot for the help.
27 Kudos
Post 7 of 7
07-31-2012 09:05 AM in reply to: OrgadataPST
No problem.
If you post a working sample project, I'll take a look at it for you.
Fenton Webb
