.NET
Crash in coreconsole
3 REPLIES 3
111Auto302
456 Views, 3 Replies
We are trying to retrieve data from solid using BRep, it is working fine in normal application launch and it is getting crash while running using coreconsole. Please suggest us some solutions. We have attached both the solutions CoreConsoleTest - this solution is for reading the data in solid.
CoreConsole - this solution is the coreconsole solution, which is used to run the CoreConsoleTest.
3 REPLIES 3
Balaji_Ram
in reply to: 111Auto302
The .Net module loaded in AccoreConsole should not be referencing acmgd.dll
You can find details on loading a .Net module in this blog post :
http://adndevblog.typepad.com/autocad/2012/04/getting-started-with-accoreconsole.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
111Auto302
in reply to: Balaji_Ram
Thanks Balaji,
The information that you have provided is not sufficient, we are still facing the same issue. Can you provide us with some more information and solution.
Balaji_Ram
Sorry for the delay in getting back to you.
I have attached the sample project, the script file and the test drawing that worked ok using accoreconsole that is part of AutoCAD 2014 install folder.
Balaji
Balaji
”Boost
