on the sql suggestion, what if I need databases that are not on a server?
mdb works, but has anyone tried using an xml file as the database?
You could load it into a dataset, and have the ds write back as needed.
I guess that would not allow concurrent use though. I'm more interested in speed though.
Are there any other good "standalone" database formats that work with ADO.net?
Mikko <>
|>What I recommend has no bearing, you have to produce the results whereas I don't.
|>Personally, I would scrape Access and go with SQL Server Express 2008 which will be released at the end of the month. You can use the 180 day Enterprise version till then. http://www.microsoft.com/express/sql/default.aspx or the 2005 version, but upgrade to 2008 for the new features when released.
|>Use one of the new 2008 Visual Studio editions or an Express version. The VB Express edition is found here. http://www.microsoft.com/express/vb/
|>I would use WPF because of the coolness factor and ease of use. One of the last hurdles, the datagrid, has just been released the other day. http://www.codeplex.com/wpf/Release/ProjectReleases.aspx?ReleaseId=14963 most every thing else has been baked in.
|>I would use LINQ because its easy. http://msdn.microsoft.com/en-us/library/bb397926.aspx
|>Go with AutoCAD 2009 or at least 2008 and keep reading these forums and use the ACAD HELP : ADDITIONAL RESOURCES : DEVELOPER HELP which is almost a cut and paste along with some verbiage editing to make it work in VB.NET. Managed VB code is a different beast as you found out.
|>Don't look back.
|>Is COM slower? Got to put it in perspective. How long is it taking you to do what your doing now. How large are your drawings? For batching multiple directories with 1000's of drawings I've never had any problems with a stand-alone.exe program running unattended in my environment.
|>Lots of opinions here, best use your own judgement and run with it.
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
Does Autodesk issue service packs on
the release you are using? not likely.
