.NET
Member
guidorooms
Message 1 of 6 (251 Views)
Counting Items in a Collection
251 Views, 5 Replies
06-09-2012 02:36 AM
Hi to all,
Since collections like for example the LayerTable have no Count property (as far as I can see, that is), I'm doing the following to get at the number of items:
Dim LayerCount as integer = 0
For Each Id as ObjectId in SomeLayerTable
    LayerCount +=1
Next
Is this the right way to do it, or is there a more efficient way?
Thanks in advance for your reply.
At least it's one of the ways that work.
You should take care of the .IsErased and .IsHidden property as (depending on how you got the layertable) you may count also layers that the user don't see in the layerdialog.
- alfred -
Alfred.NESWADBA
Message 2 of 6 (248 Views)
Re: Counting Items in a Collection
06-09-2012 03:04 AM in reply to: guidorooms
- alfred -
Alfred NESWADBA
Member
guidorooms
Message 3 of 6 (235 Views)
06-09-2012 07:44 AM in reply to: Alfred.NESWADBA
 "you may count also layers that the user don't see in the layerdialog"
Hadn't thought about that! Goodyou mentioned that.
Thanks a lot.
Hallex
Message 4 of 6 (231 Views)
06-09-2012 08:16 AM in reply to: guidorooms
Yo could be use Linq also, but it would be
a bit slower, e.g
        'Imports System.Linq
        <CommandMethod("cnt", CommandFlags.Modal Or CommandFlags.Session)> _
        Public Shared Sub GetLayerCount()
            Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim LayerCount As Integer = 0
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Dim lt = CType(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
                Dim cnt = (From id As ObjectId In lt
                         Where Not id.IsNull AndAlso Not id.IsErased
                         Select id).Count
                ed.WriteMessage(vbLf + "Layers in the currrent drawing: {0}", cnt)
            End Using
        End Sub
~'J'~
Valued Mentor
jeff
Message 5 of 6 (201 Views)
06-09-2012 02:44 PM in reply to: Hallex
Writing extension methods that return  IEnumrable can be very helpful
A example by Tony T
http://www.theswamp.org/index.php?topic=41311.msg464457#msg464457
No reason to iterate layertable twice but did for this example
  [CommandMethod("LayerCount")]
        public void LayerCount()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction trx = db.TransactionManager.StartTransaction())
                LayerTable lt = db.GetLayerTable();
                var layers = lt.GetLayerTableRecords()
                    .Where(layer => !layer.IsHidden);
                var erasedLayers = lt.GetLayerTableRecords(OpenMode.ForRead, true)
                    .Where(layer => layer.IsErased);
                ed.WriteMessage("\nLayers " + layers.Count().ToString());
                ed.WriteMessage("\nHidden Layers " + erasedLayers.Count().ToString());
                trx.Commit();
You can also find your answers @ TheSwamp
Valued Mentor
jeff
Message 6 of 6 (191 Views)
06-09-2012 05:25 PM in reply to: jeff
Did not think that through as usual but the GetLayerTable extension method probably should have overloads that the parameters indicate to include erased objects, and since a LayerTableRecord can't be on a locked layer it could return all unlocked layers instead to resemble GetObject
