.NET
.NET
Active Contributor
0 Kudos
Post 1 of 18
Could not load file or assembly 'accoremgd.dll' or one of its dependencies.
3785 Views, 17 Replies
09-11-2012 07:42 PM
Hi All,
I want to create a silent acad process in background and do some works, it works well in AutoCAD 2012. But when I upgrade to AutoCAD 2013, it cannot works. I already had referenced accoremgd.dll. It compiles well, I get the errors "Could not load file or assembly 'accoremgd.dll' or one of its dependencies . The specified module could not be found." when I run my program. Who can tell me what dlls i lose to referenced.
Yu
With code like this:
Autodesk.AutoCAD.DatabaseServices.Database db = new Autodesk.AutoCAD.DatabaseServices.Database(false, true);
It is absolutely impossible to use it in a standalone EXE (as the other reply poited out) since the very begining of AutoCAD .NET API (Acad2005). Yet, you claimed that your code worked with Acad 2012? What was your magic then?
Anyway, since you use Acad2013, and want to run "silent" instance of AutoCAD, how about Acad2013 Core Console, a non-graphical AutoCAD instance. See this post from Kean:
http://through-the-interface.typepad.com/through_the_interface/2012/02/the-autocad-2013-core-console.html
The reason why AutoCAD's managed API cannot be used from another process is because it is dependent on AutoCAD itself, and on AutoCAD DLLs that cannot be loaded into another process. For example, some managed APIs call code in acad.exe, which you can't load into your application.
Some of AutoCAD's components (the parts that allow access to Databases and object in them) can be loaded into another process with a RealDWG license.
Active Contributor
0 Kudos
Post 2 of 18
Re: Could not load file or assembly 'accoremgd.dll' or one of its dependencies.
09-11-2012 07:46 PM in reply to: yuh0317
The following dlls had been referenced.
accoremgd
acdbmgd
acmgd
Autodesk.AutoCAD.Interop
Autodesk.AutoCAD.Interop.Common
Yu
Distinguished Mentor
91 Kudos
Post 3 of 18
09-11-2012 09:01 PM in reply to: yuh0317
Is Copy Local set to false?
Gaston Nunez
Active Contributor
0 Kudos
Post 4 of 18
09-12-2012 12:48 AM in reply to: yuh0317
No matter the value is false or true. The issue is still reproducible.
Yu
Active Contributor
0 Kudos
Post 5 of 18
09-12-2012 01:23 AM in reply to: yuh0317
I only create a database object, there is a exception message "Could not load file or assembly 'accoremgd, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
AutoCAD 2013 32-bit.
I have attached sample codes.
Active Contributor
0 Kudos
Post 6 of 18
09-12-2012 01:24 AM in reply to: yuh0317
I add the following references
accoremgd
acdbmgd
acmgd
Moderator
277 Kudos
Post 7 of 18
09-12-2012 01:55 AM in reply to: yuh0317
Are you trying to create standalone exe-file?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
0 Kudos
Post 8 of 18
09-12-2012 03:42 AM in reply to: Alexander.Rivilis
Yes, I want to create standalone exe-file. And run AutoCAD 2013 in the background in the silent mode.
Yu
Moderator
277 Kudos
Post 9 of 18
09-12-2012 03:47 AM in reply to: yuh0317
Yu
It is impossible using acdbmgd.dll, acmgd.dll and accoremgd.dll in standalone exe-file.
Its can be using only in dll-file which loaded into AutoCAD.
So you can use:
Active Contributor
0 Kudos
Post 10 of 18
09-12-2012 04:59 AM in reply to: Alexander.Rivilis
Actually I want to use some class in the acdbmgd.dll, acmgd.dll and accoremgd.dll in standalone exe-file. Do you know any other ways to use some class in the acdbmgd.dll, acmgd.dll and accoremgd.dll except load my dlls by AutoCAD.
YU
