.NET
CopyObjects function problem
6 REPLIES 6
655 Views, 6 Replies
Hello, is there anybody in there?
Function, which should create new layout, a copy of available layout, in one
document, written on C#:
private void layout_new(String strFrom, String strTo,
Autodesk.AutoCAD.Interop.AcadDocument doc)
Autodesk.AutoCAD.Interop.Common.AcadLayout objLayOut;
Autodesk.AutoCAD.Interop.Common.AcadLayout objNewLayOut;
objNewLayOut = doc.Layouts.Add(strTo);
objLayOut=colLayOuts.Item(strFrom);
object[] objEntArray = new object[objLayOut.Block.Count];
int intCnt = 0;
foreach (Autodesk.AutoCAD.Interop.Common.AcadObject objEnt in
objLayOut.Block)
objEntArray[intCnt] = objEnt;
intCnt=intCnt+1;
try
doc.CopyObjects(objEntArray[1], objNewLayOut.Block,
ref missing);
objNewLayOut.CopyFrom((Autodesk.AutoCAD.Interop.Common.AcadPlotConfiguration)objLayOut);
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show(ex.ToString());
Gives out a COMException (0x8021007B) "Incorrect file of objects"
at line "doc.CopyObjects(objEntArray[1], objNewLayOut.Block, ref missing);"
Prompt, please, in what there can be a problem?
Beforehand thanks!
Wish you were here, All!
np: Jimmy Page - Liquid Mercury
6 REPLIES 6
Artem Shutov to All × Wed, 24 May 2006 07:29:15 +0000:
... _missing_ ...
AS> doc.CopyObjects(objEntArray[1],
objNewLayOut.Block,
AS> ref missing);
Sorry , mean doc.CopyObjects(objEntArray, objNewLayOut.Block, ref
missing);
and:
AS> Gives out a COMException (0x8021007B) "Incorrect array of objects"
... _missing_ ...
Wish you were here, Artem!
np: Jimmy Page & Robert Plant - Shining In The Light
Try this code:
[code]
private static void DuplicateLayout(String strFrom, String strTo,
Autodesk.AutoCAD.Interop.Common.AcadLayout objLayOut = null;
Autodesk.AutoCAD.Interop.Common.AcadLayout objNewLayOut = null;
try
objLayOut = doc.Layouts.Item(strFrom);
objNewLayOut = doc.Layouts.Item(strTo);
catch (System.Exception)
if (objLayOut != null && objNewLayOut != null)
Object missing = Type.Missing;
try
Autodesk.AutoCAD.Interop.Common.AcadEntity[] blks =
new Autodesk.AutoCAD.Interop.Common.AcadEntity[objLayOut.Block.Count];
for (int j=0; j < blks.Length; j++) {
blks = objLayOut.Block.Item(j);
doc.Database.CopyObjects(blks, objNewLayOut.Block, ref missing);
[/code]
Alexander Rivilis at Wed, 24 May 2006 23:23:25 +0000:
AR> Try this code:
AR> [code]
... _ÐÒÏÐÕÝÅÎÏ_ ...
AR> [/code]
Many thanks!
It works!
Wish you were here, Alexander!
np: John Mayall - What'd I Say
In which dll do I find Autodesk.AutoCAD.Interop.Common?
NathTay
Add Reference > COM Tab > AutoCAD 200? Type Library.
Regards - Nathan
Ok, I got an exclamation mark on the added AutoCad refference in Visual Studio.
Do you know how it can be that?
”Boost
