.NET
Copying and pasting XData between drawings
6 REPLIES 6
SRSDS
543 Views, 6 Replies
Hi again,
How can know if entities are being manually copied and pasted between drawings.
A thought is to add a GUID to each entities Xdata and check if the value is in the named object dictionary.
6 REPLIES 6
Alfred.NESWADBA
in reply to: SRSDS
good idea, but copying the drawing (with file-copy) is not prevented with this way.
Not as criticism, just as info to think of it!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
SRSDS
in reply to: Alfred.NESWADBA
ohh.. good point!
I will read the filename also as a second measure. Filenames might be the same as well but both would be rare.
Or maybe the file creation date and time.
Probably no need to write anything as data. I just need to read the identifiers during copy and paste to see if they don't match.
Thanks again.
Alfred.NESWADBA
in reply to: SRSDS
not sure what your global direction is. For me and my way of work, the filename is used as variable as possible.
1) On one side I save with a drawing-name ending with 2-4 digits as version-number and from time to time I do a _SAVEAS and increase the number.
2) On the other side, I transfer the files between computers (e.g. to home-office), continue to work and then copy it back (will be an allowed copy?)
3) not to forget, what if you get a file back by restoring from a backup-system (also allowed filecopy, isn't it?)
...and I think that there are a lot more reasons to copy a file and it sould be also valid out of your sight.
I think (without something like a data-managementserver, where the files are not stored in a filessystem you can directly access) it will not be possible to handle a filecopy with data stored within the DWG-file, that on one side allows the above variations but limit some - from your point of view - "not allowed"mechanism of copying.
Within the dataserver you have document-id's that give you the possibility of using a unique-id that you cannot get from a filesystem. However, also handling that with the fileserver is a challange.
Maybe you could describe more of "for what reason" are you doing that, then there may come some better ideas than this one.
- alfred -
Alfred NESWADBA
SRSDS
I really just need to know if the objects being pasted into a drawing have been copied from the same drawing.
COPYBASE command is the only event I need to consider.
I’ll tell users that other methods like inserting a drawing as a block then exploding isn't supported.
Maybe the file creation date and time is a good unique identifier to monitor.
Dim FileCreationTime As String = File.GetCreationTime(db.Filename())
Alfred.NESWADBA
in reply to: SRSDS
I even don't know what type of copy is now allowed, sorry. Why do you have to watch only _COPYBASE, there is also _COPYCLIP and also I think that not creating the copy-buffer will be the problem but the _PASTE*-methods have to be watched (or is it also not allowed to create a copy of geometry into MS-Word for documentation?).
The file-creation-date will also fail with my above types (backup-restore/copy to home-office/version-numbering).
And if you write EEDs and NOD, how will you handle the situation of home-work? Will you ensure that the home-pc will also run your application every time AutoCAD starts (and with any AutoCAD-profile and ...)
Now, after reading that .... all I'm writing look so pessimistic. Please understand that just as ideas, not as "all is nonesens"!
- alfred -
Alfred NESWADBA
SRSDS
Hi Alfred.
Sorry. First time I've done this and have no experience at all.
I personally only use COPYBASE between drawings. I wasn't thinking about COPYCLIP or CUTCLIP but will now.
Filename including the path should solve the drawing identification problem I think (checking source dwg = destination dwg). Two open drawings will never the same filepath & filename.
”Boost
