.NET
copy table from dwg
4 REPLIES 4
Barabasishe
672 Views, 4 Replies
copy table from dwg
Hi
i try to copy one table from dwg to current dwg which is opened. I have a little success - my table is copied to current dwg. But when i click text in cell or  try to activate table, AutoCAD hangs.
I think that my code does not copy the table. And these table that i see in the current dwg this is table from source dwg.
It's my opinion
Now i want hearing some suggestions, solutions or advices. Help.
4 REPLIES 4
Hallex
in reply to: Barabasishe
Try this way, but don't forget to rename the source file name in the code:
        [CommandMethod("ty", CommandFlags.Session)]
        public void tryCopyTable()
            //source drawing name:
            string fname = @"c:\test\workingdrawing.dwg";
            ObjectId id = ObjectId.Null;
            ObjectIdCollection ids = new ObjectIdCollection();
            IdMapping map = new IdMapping();
            bool ok = false;
            try
                DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
                Document doc = dm.MdiActiveDocument;
                Editor ed = doc.Editor;
                Database db = doc.Database;
                using (doc.LockDocument())
                    using (Transaction tr = doc.TransactionManager.StartTransaction())
                        Document doc2 = dm.Open(fname, false);
                        while (!dm.IsApplicationContext)
                            // get a time to next drawing to wake up
                            System.Threading.Thread.Sleep(1);
                        Database db2 = doc2.Database;
                        Editor ed2 = doc2.Editor;
                        ed2.WriteMessage("\nYou're may use editor in the drawing: \"{0}\"\n", fname);
                        using (Transaction tr2 = doc2.TransactionManager.StartTransaction())
                            id = ed2.GetEntity("\nSelect table to copy: ").ObjectId;
                            DBObject obj = (DBObject)tr2.GetObject(id, OpenMode.ForRead, false, true);
                            Table tbl = obj as Table;
                            if (tbl == null) return;
                            ids.Add(id);
                            tr2.Commit();
                        dm.MdiActiveDocument = doc;
                        HostApplicationServices.WorkingDatabase = doc.Database;
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false) as BlockTableRecord;
                        db2.WblockCloneObjects(ids, btr.ObjectId, map, DuplicateRecordCloning.Replace, false);
                        id = ed.SelectLast().Value.GetObjectIds()[0];
                        DBObject clone = (DBObject)tr.GetObject(id, OpenMode.ForRead, false, true);
                        Table copytbl = clone as Table;
                        if (!copytbl.IsWriteEnabled) copytbl.UpgradeOpen();
                        Point3d pt = ed.GetPoint("\nPick new insertion point: \n").Value;
                        copytbl.TransformBy(Matrix3d.Displacement(pt - copytbl.Position));
                        tr.Commit();
                        doc2.CloseAndDiscard();
                        ok = true;
            catch (System.Exception ex)
                ok = false;
                MessageBox.Show(ex.Message + "\n" + ex.StackTrace);
            finally
                if (ok)
                    MessageBox.Show("Pokey!");
Barabasishe
in reply to: Hallex
Yeah.
My code is similar to yours, but i miss some part of code:
   Point3d pt = new Point3d(0, 0, 0);
Now, my solution of this problem (without Editor and choice table, only search):
        [CommandMethod("CPTBL")]
        public void copyTable()
            Document document = Application.DocumentManager.MdiActiveDocument;
            Database database = document.Database;
            Database tempDatabase = loadDWG(@"..\myFile.dwg");
            ObjectIdCollection idColl = new ObjectIdCollection();
            ObjectId idCopiedTable = ObjectId.Null;
            try
                if (tempDatabase != null)
                    ObjectId idLayout = getLayoutFromDictionary(ref tempDatabase, "Model");
                    using (Transaction tempTransaction =
                                       tempDatabase.TransactionManager.StartTransaction())
                        BlockTableRecord tempRecord =
                                         tempTransaction.GetObject(idLayout,
        OpenMode.ForRead,
                        foreach (ObjectId idEntity in tempRecord)
                            Entity entity =
                                   tempTransaction.GetObject(idEntity,
                                                             OpenMode.ForRead,
                                                             false) as Entity;
                            Table table = entity as Table;
                            if (table != null)
                                idCopiedTable = table.ObjectId;
                                idColl.Add(table.ObjectId);
                            tempTransaction.Commit();
                    if (idColl.Count != 0)
                        using (Transaction transact =
                                           database.TransactionManager.StartTransaction())
                            BlockTableRecord record =
                                             transact.GetObject(database.CurrentSpaceId,
        OpenMode.ForWrite,
                            IdMapping mapping = new IdMapping();
                            tempDatabase.WblockCloneObjects(idColl,
                                                            record.ObjectId,
                                                            mapping,
                                                            false);
                            foreach (ObjectId idRec in record)
                                Entity entity =
                                       transact.GetObject(idRec,
                                                          OpenMode.ForRead,
                                                          false) as Entity;
                                if (table != null)
                            Table cloneTable = transact.GetObject(idCopiedTable,
        OpenMode.ForRead,
        false,
        true) as Table;
                            if (!cloneTable.IsWriteEnabled)
                                cloneTable.UpgradeOpen();
                            Point3d pointInsertion = new Point3d(0, 0, 0);
                            cloneTable.Position = pointInsertion;
                            transact.Commit();
                    tempDatabase.CloseInput(true);
                System.Windows.Forms.MessageBox.Show(ex.Message + "\n\n" + ex.StackTrace);
Barabasishe
in reply to: Hallex
Thanks, you help me out again=)
Hallex
Glad I could help
Cheers Smiley Happy
”Boost
