.NET
Active Member
0 Kudos
Post 1 of 5
copy table from dwg
321 Views, 4 Replies
11-21-2012 01:55 AM
Hi
i try to copy one table from dwg to current dwg which is opened. I have a little success - my table is copied to current dwg. But when i click text in cell or  try to activate table, AutoCAD hangs.
I think that my code does not copy the table. And these table that i see in the current dwg this is table from source dwg.
It's my opinion
Now i want hearing some suggestions, solutions or advices. Help.
Yeah.
My code is similar to yours, but i miss some part of code:
 DBObject clone = (DBObject)tr.GetObject(id, OpenMode.ForRead, false, true);
Table copytbl = clone as Table;
if (!copytbl.IsWriteEnabled) copytbl.UpgradeOpen();
Point3d pt = new Point3d(0, 0, 0);
copytbl.TransformBy(Matrix3d.Displacement(pt - copytbl.Position));
Now, my solution of this problem (without Editor and choice table, only search):
 [CommandMethod("CPTBL")]
public void copyTable()
Document document = Application.DocumentManager.MdiActiveDocument;
Database database = document.Database;
Database tempDatabase = loadDWG(@"..\myFile.dwg");
ObjectIdCollection idColl = new ObjectIdCollection();
ObjectId idCopiedTable = ObjectId.Null;
try
if (tempDatabase != null)
ObjectId idLayout = getLayoutFromDictionary(ref tempDatabase, "Model");
using (Transaction tempTransaction =
tempDatabase.TransactionManager.StartTransaction())
BlockTableRecord tempRecord =
tempTransaction.GetObject(idLayout,
OpenMode.ForRead,
false) as BlockTableRecord;
foreach (ObjectId idEntity in tempRecord)
Entity entity =
tempTransaction.GetObject(idEntity,
OpenMode.ForRead,
false) as Entity;
Table table = entity as Table;
if (table != null)
idCopiedTable = table.ObjectId;
idColl.Add(table.ObjectId);
tempTransaction.Commit();
if (idColl.Count != 0)
using (Transaction transact =
database.TransactionManager.StartTransaction())
BlockTableRecord record =
transact.GetObject(database.CurrentSpaceId,
OpenMode.ForWrite,
IdMapping mapping = new IdMapping();
tempDatabase.WblockCloneObjects(idColl,
record.ObjectId,
mapping,
DuplicateRecordCloning.Replace,
false);
foreach (ObjectId idRec in record)
Entity entity =
transact.GetObject(idRec,
OpenMode.ForRead,
false) as Entity;
if (table != null)
Table cloneTable = transact.GetObject(idCopiedTable,
OpenMode.ForRead,
false,
true) as Table;
if (!cloneTable.IsWriteEnabled)
cloneTable.UpgradeOpen();
Point3d pointInsertion = new Point3d(0, 0, 0);
cloneTable.Position = pointInsertion;
transact.Commit();
tempDatabase.CloseInput(true);
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show(ex.Message + "\n\n" + ex.StackTrace);
171 Kudos
Post 2 of 5
Re: copy table from dwg
11-21-2012 09:24 AM in reply to: Barabasishe
Try this way, but don't forget to rename the source file name in the code:
        [CommandMethod("ty", CommandFlags.Session)]
        public void tryCopyTable()
            //source drawing name:
            string fname = @"c:\test\workingdrawing.dwg";
            ObjectId id = ObjectId.Null;
            ObjectIdCollection ids = new ObjectIdCollection();
            IdMapping map = new IdMapping();
            bool ok = false;
            try
                DocumentCollection dm = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
                Document doc = dm.MdiActiveDocument;
                Editor ed = doc.Editor;
                Database db = doc.Database;
                using (doc.LockDocument())
                    using (Transaction tr = doc.TransactionManager.StartTransaction())
                        Document doc2 = dm.Open(fname, false);
                        while (!dm.IsApplicationContext)
                            // get a time to next drawing to wake up
                            System.Threading.Thread.Sleep(1);
                        Database db2 = doc2.Database;
                        Editor ed2 = doc2.Editor;
                        ed2.WriteMessage("\nYou're may use editor in the drawing: \"{0}\"\n", fname);
                        using (Transaction tr2 = doc2.TransactionManager.StartTransaction())
                            id = ed2.GetEntity("\nSelect table to copy: ").ObjectId;
                            DBObject obj = (DBObject)tr2.GetObject(id, OpenMode.ForRead, false, true);
                            Table tbl = obj as Table;
                            if (tbl == null) return;
                            ids.Add(id);
                            tr2.Commit();
                        dm.MdiActiveDocument = doc;
                        HostApplicationServices.WorkingDatabase = doc.Database;
                        BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false) as BlockTableRecord;
                        db2.WblockCloneObjects(ids, btr.ObjectId, map, DuplicateRecordCloning.Replace, false);
                        id = ed.SelectLast().Value.GetObjectIds()[0];
                        Point3d pt = ed.GetPoint("\nPick new insertion point: \n").Value;
                        tr.Commit();
                        doc2.CloseAndDiscard();
                        ok = true;
                ok = false;
                MessageBox.Show(ex.Message + "\n" + ex.StackTrace);
            finally
                if (ok)
                    MessageBox.Show("Pokey!");
Active Member
0 Kudos
Post 3 of 5
11-21-2012 08:31 PM in reply to: Hallex
Yeah.
            try
        OpenMode.ForRead,
                            Entity entity =
                                                             OpenMode.ForRead,
                                                             false) as Entity;
                            if (table != null)
        OpenMode.ForWrite,
                                                            record.ObjectId,
                                                            mapping,
                                                            false);
                                Entity entity =
                                                          OpenMode.ForRead,
                                                          false) as Entity;
                                if (table != null)
        OpenMode.ForRead,
        false,
        true) as Table;
                            transact.Commit();
Active Member
0 Kudos
Post 4 of 5
11-21-2012 08:43 PM in reply to: Hallex
Thanks, you help me out again=)
171 Kudos
Post 5 of 5
11-21-2012 10:08 PM in reply to: Barabasishe
Glad I could help
Cheers :smileyhappy:
