.NET
Copy PolyLine to new file Error Warning: An error occurred during save...
2 REPLIES 2
Martin60
624 Views, 2 Replies
I am copying objects to a new database and and cloning as an Entity type succesfully for all objects.
When I save the database to a new file I get the attached error
'Warning: An error occurred during save....'
I have isolated this to Polylines and have tried to Process as Type PolyLine but still get the error.
Here is the code I use for the polyline.
(My entity processing code is identical except for object type).
        Dim MyPolyLine As DatabaseServices.Polyline
        MyPolyLine = CType(myObjID.GetObject(DatabaseServices.OpenMode.ForRead),  _
        DatabaseServices.Polyline)
        Dim NewEntity As DatabaseServices.Polyline = CType(MyPolyLine.Clone,  _
        NewEntity.SetDatabaseDefaults(NewDB)
        NewBTR.AppendEntity(NewEntity)
        NewTrans.AddNewlyCreatedDBObject(NewEntity, True)
        NewEntity.Layer = MyPolyLine.Layer
        NewEntity.Linetype = "ByLayer"
        NewEntity.Material = "ByLayer"
Martin
2 REPLIES 2
StephenPreston
in reply to: Martin60
Using Clone to copy objects is dangerous - it performs a shallow clone of the entity. I suggest you use Database.WblockCloneObjects or Database.DeepcloneObjects (depending on whether you're copying between databases or between them).
Cheers,
Stephen Preston
Autodesk Developer Network
Martin60
in reply to: StephenPreston
Thanks Stephen
The Database.WblockCloneObjects method was the one I needed.
Certainly removed my problem and simplified my code.
No longer needed to manage layers and BlockReferences need no additional handling.
Thanks again
Martin
”Boost
