.NET
.NET
Active Member
0 Kudos
Post 1 of 22
Copy paste with new block definition
838 Views, 21 Replies
09-08-2011 06:35 AM
I'm trying to develop one tool with that objective:
  • Let the user select Blocks into the current drawing
  • For each block selected, create a new Block definition and copy all objects inside. " new block definition and objects inside may not be referenced with our selected block".
  • Paste all objects created where user wants
Problems :
I was trying copy objects using .clone or .copyfrom but i don't know how to copy objects without references between new and selected block.
 My Code :
    Dim acdoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acdoc.Database
        Dim acBt As BlockTable
        Dim acBtr As BlockTableRecord
        Dim E As Integer
        Dim newBtrId As ObjectId
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction
            acBt = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
            acBtr = acTrans.GetObject(acBt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            'Let the user select Objects from drawing
            Dim acSSPrompt As PromptSelectionResult = acdoc.Editor.GetSelection()
            If acSSPrompt.Status = PromptStatus.OK Then
                Dim acSSet As SelectionSet = acSSPrompt.Value
                'Paste position
                Dim myPoint As PromptPointResult = acdoc.Editor.GetPoint("Paste point: ")
                'Read Selection Set
                For Each acSSObj As SelectedObject In acSSet
                    'Look for ObjectId of my Selected Object
                    For Each acObjId As ObjectId In acBtr
                        If acObjId = acSSObj.ObjectId Then
                            'Take selected object as Blockreference
                            Dim Et As Entity = acTrans.GetObject(acObjId, OpenMode.ForWrite)
                            If TypeOf Et Is BlockReference Then
                                'Current Block Selected
                                Dim Br As BlockReference = Et
                               'Here I should Paste all objects from Br to BlkRef ...
                                'Create a new BlockTableRecord
                                Dim blkRef As BlockTableRecord = New BlockTableRecord()
                                blkRef.Name = "beta" & E + 1
                                'Add BlockTableRecord
                                newBtrId = acBt.Add(blkRef)
                                acTrans.AddNewlyCreatedDBObject(blkRef, True)
                                'Paint BlockReference
                                Dim bob As New BlockReference(myPoint, newBtrId)
                                acBtr.AppendEntity(bob)
                                acTrans.AddNewlyCreatedDBObject(bob, True)
                                E = E + 1
                            End If
                        End If
                    Next
                Next
                acTrans.Commit()
            End If
        End Using
    End Sub
 Any idea will be apreciated !
Thank's a lot!
This was thrown together very quickly need error handling etc....
 <CommandMethod("DeepCloneBlock")> _
Public Sub DeepCloneBlock()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Using trx As Transaction = db.TransactionManager.StartTransaction()
Dim tvs() As TypedValue = {New TypedValue(0, "INSERT")}
Dim selectionFilter As New SelectionFilter(tvs)
Dim result As SelectionSet = ed.GetSelection(selectionFilter).Value
Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForWrite)
For Each objId As ObjectId In result.GetObjectIds
Dim bref As BlockReference = trx.GetObject(objId, OpenMode.ForRead)
Dim btr As BlockTableRecord = trx.GetObject(bref.BlockTableRecord, OpenMode.ForRead)
If Not bt.Has(btr.Name & " Copy") Then
Dim map As New IdMapping()
Dim newBtr As BlockTableRecord = btr.DeepClone(bt, map, False)
newBtr.Name = btr.Name & " Copy"
bt.Add(newBtr)
trx.AddNewlyCreatedDBObject(newBtr, True)
End If
Next
trx.Commit()
End Using
End Sub
54 Kudos
Post 2 of 22
Re: Copy paste with new block definition
09-08-2011 12:16 PM in reply to: PaulPotts
I would call the .Explode method on each of the selected blocks, then add the entities created by .Explode to the new BlockTableRecord.
'first declare a New DbObjectCollection
Dim ExpObjs as New DbObjectCollection()
'I would change this loop   "For Each acSSObj As SelectedObject In acSSet" to ->
For Each AcObjId as ObjectId in acSSet.GetObjectIds
'And lose this loop altogether "For Each acObjId As ObjectId In acBtr"
    Br.Explode(ExpObjs)
    For Each dbo as DbObject in ExpObjs
         blkref.AppendEntity(dbo)
         acTrans.AddNewlyCreatedDbObject(dbo, True)
    Next
Edit:  I am slightly confused as to whether you intend to create 1 new block for each block selected, or 1 new block containing all blocks selected, and unfortunately the example as typed is a combination of the two.  If you want a new block to be created for each of the blocks selected, then you should move the declaration of the New DbObjectCollection to inside the For Loop.  If you want one new block containing all of the selected blocks, then you should move the new For Loop (for each dbo as DbObject in ExpObjs) and the new block insert to outside the main For Loop.
Active Member
0 Kudos
Post 3 of 22
09-08-2011 01:06 PM in reply to: chiefbraincloud
Thank's chief !
I would like one new block definition for each block selected,
I'm gonna try what you said thank you very very much ! :smileywink:
Active Member
0 Kudos
Post 4 of 22
09-09-2011 01:31 AM in reply to: PaulPotts
I was trying your answer but i have an error on:
          For Each dbo As DBObject In ExpObjs
                            blkRef.AppendEntity(dbo)
                            acTrans.AddNewlyCreatedDBObject(dbo, True)
          Next
Autodesk.AutoCAD.Runtime.Exception: eNotInDatabase   Autodesk.AutoCAD.DatabaseServices.TransactionManager.AddNewlyCreatedDBObject(DBObject obj, Boolean add)
All code :
 Public Sub Copy_Paste()
        Dim E As Integer
                For Each AcObjId As ObjectId In acSSet.GetObjectIds
                    Dim Et As Entity = acTrans.GetObject(AcObjId, OpenMode.ForWrite)
                        Dim ExpObjs As New DBObjectCollection()
                        Br.Explode(ExpObjs)
                        Next
                        E = E + 1
                    End If
                Next
            End If
        End Using
    End Sub
 i don't know what i'm missing...
thank's !
1,210 Kudos
Post 5 of 22
09-09-2011 01:45 AM in reply to: PaulPotts
you do create a BlockTableRecord (blkRef)
then you add objects into this blockdefinition and - now the error - the transaction should add an object to a blockreference, that is not known by the transaction.
So: after creating the BlockTableRecord ==> add this to the BlockTable and to the current transaction
After that (!) add objects to the BlockTableRecord.
So the code-snippet should look like:
'now these two lines where moved upwards
Next
HTH, - alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 6 of 22
09-09-2011 07:07 AM in reply to: Alfred.NESWADBA
Thank's ! it works  :smileyhappy: !!
I missed to copy all attributes to the new block , I tried doing as what i pasted here, but i think that's not the correct way to do it :
                      For Each atrib As ObjectId In Br.AttributeCollection
                            Dim att As AttributeReference
                            att = acTrans.GetObject(atrib, OpenMode.ForWrite)
                            blkRef.AppendEntity(att)
                            acTrans.AddNewlyCreatedDBObject(att, True)
                        Next
 How i could add into a blocktablerecord an Attribute ?
54 Kudos
Post 7 of 22
09-09-2011 10:55 AM in reply to: PaulPotts
Sorry I missed that Paul, but yes, as you have discovered, the BlockTableRecord must be Database Resident before you start adding thins to it.
To be thorough, I should also mention that the Explode method will fail if the block is not Uniformly Scaled, just as the AutoCAD Explode command does.
As far as the attributes, You should open the BlockTableRecord of the BlockReference you are exploding, and create new AttributeReferences from the AttributeDefinitions in the BlockTableRecord.
To be honest, having to do that means you almost might as well just copy everything to your new block from there, and skip the Explode.  I'll spend a few minutes working up a sample.
Valued Mentor
53 Kudos
Post 8 of 22
09-09-2011 11:25 AM in reply to: chiefbraincloud
Why don't you just get the BlockTableRecord of the BlockReference and DeepClone it?
You can also find your answers @ TheSwamp
54 Kudos
Post 9 of 22
09-09-2011 11:31 AM in reply to: jeff
Frankly, I was trying to stick closer to his code and pick it up from there, but as I was just working on it, I realized that a deep clone would be easier, faster, and avoid the problem of non-uniformly scaled block references.
Valued Mentor
53 Kudos
Post 10 of 22
09-09-2011 12:08 PM in reply to: chiefbraincloud
                        bt.Add(newBtr)
                    End If
                Next
                trx.Commit()
            End Using
        End Sub
