.NET
copy/paste text box
0 REPLIES 0
Message 1 of 1
cadcamm99
605 Views, 0 Replies
copy/paste text box
I put in a copy/paste routine for a text box but it keeps pasting the text twice when I do cntrl+v. Any ideas why?
Private Sub tbPartNo02_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles tbPartNo02.KeyPress
        Dim KeyAscii As Integer = Asc(e.KeyChar)
        Dim byt As Byte = Convert.ToByte(e.KeyChar)
        If byt = 24 Then 'Ctrl+X number in alphabet
            myCut()
        ElseIf byt = 3 Then 'Ctrl+C number in alphabet
            myCopy()
        ElseIf byt = 22 Then 'Ctrl+V number in alphabet
            myPaste()
        Else
            Select Case KeyAscii
                Case 48 To 57 'Accept numbers 0-9
                    e.KeyChar = e.KeyChar
                Case 65 To 90 'Accept letters A-B
                Case 97 To 122 'Accept letters a-b
                    e.KeyChar = UCase(e.KeyChar)
                Case 45 'Accept dashes
                Case 8 'Accept backspace
                Case Else
                    e.Handled = True
            End Select
    End Sub
Private Sub myPaste()
        'Check if active control is a textbox
        If TypeOf Me.ActiveControl Is TextBox Then
            'Associate active control to textbox
            Dim SelectedTextbox As TextBox = Me.ActiveControl
            'Check if text in clipboard is text
            If Clipboard.GetDataObject.GetDataPresent(DataFormats.Text) Then
                'SelectedTextbox.Paste() 'Past text to active textbox
                'SelectedTextbox.SelectedText = Clipboard.GetText
                SelectedTextbox.SelectedText = CType(Clipboard.GetDataObject.GetData(DataFormats.Text), String)
    End Sub
0 REPLIES 0
”Boost
