.NET
Copy or Clone a viewport
9 REPLIES 9
Message 1 of 10
Predator_mpm
1633 Views, 9 Replies
What is the correct way of copying an existing viewport, What I am actually doing is that to clone a layout by copying what is inside it, everything works smoothly except for the viewports.
I tried to use the clone method, but it didnt work, I also tried to use the copyfrom method but also to no avail.
In both cases the copied viewport is a dumb black rectangle
Dim exkeyvport As Autodesk.AutoCAD.DatabaseServices.Viewport = DirectCast(acTrans.GetObject(objId, OpenMode.ForRead), Autodesk.AutoCAD.DatabaseServices.Viewport)
                        Dim keyvport As New Autodesk.AutoCAD.DatabaseServices.Viewport
                        keyvport.CopyFrom(exkeyvport)
                        keyvport.UpdateDisplay()
                        NewblkTableRec.AppendEntity(keyvport)
                        acTrans.AddNewlyCreatedDBObject(keyvport, True)
 The only way that partially worked for me was to create a viewport and copy its attributes one by one, but this is exhaustive and not reliable, so could anyone tell us of the proper way to copy a viewport?
9 REPLIES 9
Message 2 of 10
Predator_mpm
in reply to: Predator_mpm
Please some one answer!
Message 3 of 10
Izz_acad
Add this :
keyvport.CenterPoint = New Point3d(keyvportCenterX, keyvportCenterY, 0)
            keyvport.Width = keyvportWidth
    keyvport.Height = keyvportHeight
            keyvport.Layer = "0"
            keyvport.StandardScale = StandardScaleType.Scale1To1
                  keyvport.ViewDirection = Vector3d.ZAxis
    keyvport.ViewTarget = New Point3d(0, 0, 0)
  keyvport.ViewCenter = Point2d.Origin
            keyvport.Visible = True
keyvport.On = True
Message 4 of 10
Predator_mpm
in reply to: Izz_acad
You are changing a lot of the viewport original attributes, so this would not achieve my goals.
Message 5 of 10
Balaji_Ram
The easiest way to do that is to create a new viewport and set its view parameters based on the source viewport.
BlockTableRecord btrDest = (BlockTableRecord)Tx.GetObject(LayoutDest.BlockTableRecordId, OpenMode.ForWrite);
Viewport vp = Tx.GetObject(per.ObjectId, OpenMode.ForRead) as Viewport;
Viewport vpNew = new Viewport();
vpNew.SetDatabaseDefaults();
Point2d viewCenter = vp.ViewCenter;
vpNew.ViewCenter = viewCenter;
Point3d viewTarget = vp.ViewTarget;
vpNew.ViewTarget = viewTarget;
Vector3d viewDir = vp.ViewDirection;
vpNew.ViewDirection = viewDir;
double viewHeight = vp.ViewHeight;
vpNew.ViewHeight = viewHeight;
double viewportHeight = vp.Height;
vpNew.Height = viewportHeight;
double viewportWidth = vp.Width;
vpNew.Width = viewportWidth;
Point3d centerPoint = vp.CenterPoint;
vpNew.CenterPoint = centerPoint;
double custScale = vp.CustomScale;
vpNew.CustomScale = custScale;
double elevation = vp.Elevation;
vpNew.Elevation = elevation;
double lensLength = vp.LensLength;
vpNew.LensLength = lensLength;
bool isVisible = vp.Visible;
vpNew.Visible = isVisible;
oid = btrDest.AppendEntity(vpNew);
Tx.AddNewlyCreatedDBObject(vpNew, true);
Balaji
Developer Technical Services
Autodesk Developer Network
Message 6 of 10
Predator_mpm
I was finally able to clone the viewport, without having the need to copy each parameter alone, the way to copy a viewport is by using the deepcloneobjects method
'objid refers to the viewport object id
If (objId.ObjectClass.DxfName.ToUpper = "VIEWPORT") Then
                    Dim id As ObjectId = newLayout.BlockTableRecordId
                    Dim idcol As New ObjectIdCollection
                    idcol.Add(objId)
                    Dim idmap As New IdMapping
                    acCurdb.DeepCloneObjects(idcol, acCurdb.CurrentSpaceId, idmap, False)
End if
 The only bad thing in using this method is that I do not get the objectid of the newly created viewport, so that I can not modify it after cloning it (I wonder if there is a method to do so).
The viewport object also has a method that is deepclone(), I tried to use it but I didnt find enough documentation on how to use it, and I didn't reach a notable result.
Thanks for your answers guys
Message 7 of 10
Balaji_Ram
Glad to know that you have another solution in hand.
To get the ObjectId, look for the idmap. That should have that info.
Balaji
Message 8 of 10
Predator_mpm
in reply to: Balaji_Ram
Dear Mr
I have checked your post here:
http://adndevblog.typepad.com/autocad/2012/07/restore-previously-saved-ucs-using-objectarx.html
and your note:  This solution does not change the UCS name that is displayed by AutoCAD using the UCSNAME system variable.
Is there a solution that does the same but shows the ucs name when using the ucsname variable?
Thanks for help
Message 9 of 10
Balaji_Ram
My kind request would be to create a separate forum post for this topic.
It makes it easier for someone searching for answers later and also it is likely that you will get more than one way to solve it from the experts in this forum.
Balaji
Message 10 of 10
Predator_mpm
Sure
”Boost
