.NET
*Expert Elite*
Hallex
Message 11 of 15 (155 Views)
Re: Copy of BlockTableRecord (save as)
09-04-2012 12:11 AM in reply to: RichardCammeray
Richard, try first to create 2 similar blocks
with different names manually
and set color property for all subentities
in the first block to byblock and for the second one
to bylayer, then see what happens
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Active Contributor
RichardCammeray
Message 12 of 15 (153 Views)
09-04-2012 12:49 AM in reply to: Hallex
I have tried to create manually two blocks as you advised and inserted them into drawing (two per each one).
Then I run my version of  CopyXBref command. Unfortunately original block had change colour as well.
Thank you for your patience
Richard
*Expert Elite*
Hallex
Message 13 of 15 (145 Views)
09-04-2012 02:07 AM in reply to: RichardCammeray
No problems,
Now you try this code on your manually created block<
but create layer before, see comments at the end of code
        [CommandMethod("CopyXB")]
        public void CopyBlockDef()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect parent block instance to copy: ");
                peo.SetRejectMessage("\nMust be a type of the BlockReference!");
                peo.AddAllowedClass(typeof(BlockReference), true);
                PromptEntityResult per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK) return;
                BlockReference bref = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead);
                ed.WriteMessage("\nBlock Selected with name: {0}", btr.Name);
                PromptStringOptions pso = new PromptStringOptions("\nEnter new block name: ");
                pso.AllowSpaces = true;
                PromptResult sres = ed.GetString(pso);
                if (sres.Status != PromptStatus.OK) return;
                string newname = sres.StringResult;
                if (bt.Has(newname))
                    ed.WriteMessage("\nBlock with name: {0} already exist, try again", newname);
                    return;
                BlockTableRecord newbtr = new BlockTableRecord();
                bt.UpgradeOpen();
                newbtr = (BlockTableRecord)btr.DeepClone(bt, new IdMapping(), true);
                newbtr.Name = newname;
                bt.Add(newbtr);
                ed.Regen();
                foreach (ObjectId id in newbtr)
                    Entity ent = tr.GetObject(id, OpenMode.ForRead) as Entity;
                    if (ent == null) continue;
                    ent.UpgradeOpen();
                    ent.ColorIndex = 256;
                tr.AddNewlyCreatedDBObject(newbtr, true);
                //Change BlockReference
                bref.BlockTableRecord = newbtr.ObjectId;
                // change layer, "RedColoredLayer" must be created before
                bref.Layer = "RedColoredLayer";
                tr.Commit();
~'J'~
Active Contributor
RichardCammeray
Message 14 of 15 (124 Views)
09-04-2012 09:38 PM in reply to: Hallex
Did not work either.
I set subentities in original block to color 3 but after running this command subentities were assigned to color ByLayer (ColorIndex = 256) in new and original block.
As I said at the beginning of the thread, ObjectIds of subentities in original and new blocks are the same and that is an issue.
I decided to create new empty Block and use DeepCloneObjects instead. Example below.
Hallex, Thank you for your help and very good examples.
Richard
        [CommandMethod("CopyXC")]
        public void testCopyBlockReference()
                PromptEntityOptions peo = new PromptEntityOptions("\nSelect main block instance to copy: ");
                    return;
                ObjectIdCollection ids = new ObjectIdCollection();
                foreach (ObjectId id in btr)
                    ids.Add(id);
                bt.UpgradeOpen();
                ObjectId newBtrId = bt.Add(newbtr);
                IdMapping idMap = new IdMapping();
                db.DeepCloneObjects(ids, newBtrId, idMap, true);
                    ent.UpgradeOpen();
                    ent.ColorIndex = 1;
                bref.BlockTableRecord = newbtr.Id;
                tr.Commit();
*Expert Elite*
Hallex
Message 15 of 15 (115 Views)
09-05-2012 01:23 AM in reply to: RichardCammeray
Glad you've solved it,
Cheers :smileyhappy:
~'J'~
Announcements
Need installation help?
