I found that dotnet apps don't want to run from server without some tweaking of gac or some other things i don't understand, and don't want to mess with server settings..
what is the typical way of deploying a dot net app in a small office? 3-4 users
i was considering this lisp to copy latest server version to local drive,
opinions?
(defun LoadAppFromServer()
(setq ServerCopy "Path to server copy\\app.dll")
(setq LocalCopy "C:\\Local path\\app.dll")
;Delete local copy to ensure latest version
(vl-file-delete LocalCopy)
;Try to copy server copy to local drive
(if(vl-file-copy ServerCopy
LocalCopy)
(progn
(setq FileName LocalCopy)
(princ (strcat "\ncopied source file " ServerCopy " from server"))
(if (findfile Filename)
(command "netload" Filename)
(princ(strcat("\nFile not found" Filename)))
(progn
(princ (strcat "Failed to copy source file " ServerCopy " from server"))
;(LoadAppFromServer
The easiest way is to add some scripting to the user's login script that
compares file timestamps and copies newer files from the server to
the local system.
i don't currently have login scripts, though i could research that.
would it be functionally equivalent if i just putting that lisp in acad.lsp so it just runs once per session?
pros / cons ?
did that lisp code look ok? it works here so far but are there obvious flaws?
(other than it's not checking dates so i have to add that) but as far as deleting the old and copying the new?
thanks
You might want to check the server file exists before you delete the local file.
Andrew, good point, I know it does, but should add that to the code, thanks
mark
