.NET
cbutler1
Message 1 of 1 (105 Views)
Copy Displayset
105 Views, 0 Replies
05-23-2012 02:23 PM
We're trying to copy the Displayset but having trouble. Has anyone been able to get this to work?  Here's a snippet of one attempt:
    Public Shared Sub CopyMEPDisplaySet2(ByVal FileDB As Database, ByVal SourceDB As Database)
        Using acTrans As Transaction = FileDB.TransactionManager.StartTransaction()
            Dim dds1 As New Autodesk.Aec.DatabaseServices.DictionaryDisplaySet(FileDB, True)
            Dim dds2 As New Autodesk.Aec.DatabaseServices.DictionaryDisplaySet(SourceDB, True)
            For Each OID As ObjectId In dds1.Records
                Dim ds As Autodesk.Aec.DatabaseServices.DisplaySet = TryCast(acTrans.GetObject(OID, OpenMode.ForRead, True, True), Autodesk.Aec.DatabaseServices.DisplaySet)
                If ds IsNot Nothing Then
                    Dim dssID As ObjectId = dds2.GetAt(ds.Name)
                    If dssID.IsNull = False Then
                        Dim dss As Autodesk.Aec.DatabaseServices.DisplaySet = TryCast(dssID.GetObject(OpenMode.ForRead, True, True), Autodesk.Aec.DatabaseServices.DisplaySet)
                        ds.UpgradeOpen()
                        ds.CopyFrom(dss)
                        ds.DowngradeOpen()
                    End If
                End If
            Next
            acTrans.Commit()
        End Using
    End Sub
 This fails to successfully copy.  Here's a couple other attempts:
    Public Shared Sub CopyMEPDisplaySet1(ByVal FileDB As Database, ByVal SourceDB As Database)
            dds1.CopyFrom(dds2)
            acTrans.Commit()
        End Using
    End Sub
    Public Shared Sub CopyMEPDisplaySet3(ByVal FileDB As Database, ByVal SourceDB As Database)
        Dim objColIDS As New ObjectIdCollection()
            For Each OID As ObjectId In dds2.Records
                objColIDS.Add(OID)
            Next
            Dim helpme As New Autodesk.Aec.ApplicationServices.Utility.CloningHelper
            '  uncomment one of these if you want to have a behavior other than default (i.e., overwrite).
            'helpme.MergeType = Autodesk.Aec.OmfSamples.DictionaryRecordMergeBehavior.Unique; // rename
            helpme.MergeType = Autodesk.Aec.ApplicationServices.Utility.DictionaryRecordMergeBehavior.Overwrite
            ' no overrite + add overlapping ones as anonymous name (probably internal use only.)
            'helpme.MergeType = Autodesk.Aec.OmfSamples.DictionaryRecordMergeBehavior.Normal; // no overrite.
            '  finally call clone.
            helpme.UseTransactions = True
            helpme.IncludeDefaultDisplaySystem = True
            helpme.OverwriteDependentAutoCADObjects = True
            helpme.Clone(SourceDB, FileDB, objColIDS, dds1.GetRXClass, True)
            acTrans.Commit()
        End Using
    End Sub
Craig
