.NET
Coordinates on a Polyline
2 REPLIES 2
Jozi68
319 Views, 2 Replies
Hi All,
For a given X value, how can I find the corresponding Y values on a selected Polyline? Or maybe just a list of coordinates of vertexes in the correct order?
regards,
Jozi68
2 REPLIES 2
norman.yuan
in reply to: Jozi68
You can create a Line start at x,0 and to x,anyY (that is a vertical line), then use IntersactWith() to find the intersection point of the line and the polyline, thus the y coordinate of the intersection point is what you are looking for.
Norman Yuan
Drive CAD With Code
danny.boy.1
in reply to: Jozi68
If polyline is type lwpolyline or polyline
{code}
Dim Coords As Point3dCollection = New Point3dCollection
For i as integer = 1 To SelPoly.NumberOfVertices
Coords.Add(SelPoly.GetPoint3dAt(i - 1))
Next i
{code}
If selected poylline is poyliline2d then
{code}
For Each vId As DatabaseServices.ObjectId In SelPoly2d
Dim v2d As DatabaseServices.Vertex2d = DirectCast(myTrans.GetObject(vId, DatabaseServices.OpenMode.ForRead), DatabaseServices.Vertex2d)
Coords.Add(CType(v2d.Position, Point3d))
Next
{code}
Now you can easy get every vertex in drawing order at integer parametar i.
xi = Coords(i).x
yi = Coords(i).y
zi = Coords(i).z
i=0 to Coords.count-1
”Boost
