.NET
Converting colors
15 REPLIES 15
Message 1 of 16
Thiss
1613 Views, 15 Replies
Converting colors
How do I convert an AutoCad color to a system.drawing.color if the AutoCad. color is by Index
switch (autoCadLayer.Color.ColorMethod)
case Autodesk.AutoCAD.Colors.ColorMethod.ByColor:
System.Drawing.Color color = autoCadLayer.Color.ColorValue;
break;
case Autodesk.AutoCAD.Colors.ColorMethod.ByAci:
System.Drawing.Color color = System.Drawing.Color.FromArgb(?, ?, ?);
break;
15 REPLIES 15
Message 2 of 16
in reply to: Thiss
Perhaps try something like :
PromptSelectionOptions selectionOptions = new PromptSelectionOptions();
PromptEntityResult entityRes = ed.GetEntity("\nPick something");
//Do nothing if selection is unsuccessful
if (entityRes.Status != PromptStatus.OK)
return;
Entity ent = (Entity)tr.GetObject(entityRes.ObjectId, OpenMode.ForWrite);
if (ent.Color.IsByAci == false)
return;
System.Drawing.Color winColor = System.Drawing.Color.FromArgb(
ent.Color.ColorValue.A,
ent.Color.ColorValue.R,
ent.Color.ColorValue.G,
ent.Color.ColorValue.B
ed.WriteMessage("\n "
+ winColor.Name.ToString()
+ winColor.ToString()
/// kwb
wrote in message news:5571705@discussion.autodesk.com...
color is by Index
break;
break;
Message 3 of 16
Thiss
in reply to: Thiss
Kerry
I tried this before I posted the question.
The problem is that if the color mode is by index then the ARGB slots do not contain Red Green & Blue values. The A slot appears to be 255 and the R slot holds the index number and G & B are zero
Dave
Message 4 of 16
in reply to: Thiss
Dave,
I'd have to see your code, but ..
It looks like you're working with a LayerTableRecord
so, by my understanding,
so you should be able to do what you need from the ltr.Color.ColorValue.R
... etc, fed to the
System.Drawing.Color.FromArgb( A, R,G, B) as I've shown.
/// kwb
wrote in message news:5573590@discussion.autodesk.com...
Kerry
Dave
Message 5 of 16
Thiss
in reply to: Thiss
Kerry
Tks for reply. Here is the code. Its a common call when reading the layer table and the entities.
If I have a layer with a colour that is ByAci then in the ColorValue object I have the following
ColorValue = "{Name=ff050000, ARGB=(255, 5, 0, 0)}"
Five being the Acad index for Blue
If however I have a layer where the colour is ByValue I get the following, which is good
ColorValue = "{Name=ff2109f6, ARGB=(255, 33, 9, 246)}"
When I read the entities I use the same method
If the color is by layer I don't need to look at the entities color (it is empty anyway)
ColorValue = "{Name=ff000000, ARGB=(255, 0, 0, 0)}"
but if the color is not by layer I get exactky the same behaviour as above
Code snippet below.....
NB I'm on leave next week, so if you reply I am not ignoring you !
Many thanks
Dave
Message 6 of 16
in reply to: Thiss
Or just use EntityColor.LookUpRgb()
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Kerry Brown" wrote in message news:5574757@discussion.autodesk.com...
Dave,
... etc, fed to the
/// kwb
Kerry
Dave
Message 7 of 16
Thiss
in reply to: Thiss
Tony
Tks for joining in
What do you mean by EntityColor.LookUpRgb() ?
There is no LookUpRgb method or property on the AutoCAD.Colors.Color object.
Can you be more specific please ?
Dave
Message 8 of 16
Thiss
in reply to: Thiss
Tony
Sorry - mis understood - I see there is a static method - just tryimng it now
tks
dave
Message 9 of 16
Thiss
in reply to: Thiss
Tony
Okay - I now have this
int i = Autodesk.AutoCAD.Colors.EntityColor.LookUpRgb(acadColor.ColorValue.R);
Which returns an integer. How do I get that into RGB (in .NET)?
Tks
Dave
Message 10 of 16
in reply to: Thiss
For your LTR, just for the fun of it, how about :-
System.Drawing.Color argb = System.Drawing.Color.FromArgb(
AcColors.EntityColor.LookUpRgb(
System.Convert.ToByte(
ltr.Color.ColorIndex)));
/// kwb
wrote in message news:5575062@discussion.autodesk.com...
Tony
int i =
Tks
Dave
Message 11 of 16
in reply to: Thiss
Kerry - What's 'AcColors' ?
"Kerry Brown" wrote in message news:5575042@discussion.autodesk.com...
/// kwb
Tony
int i =
Tks
Dave
Message 12 of 16
in reply to: Thiss
Reading up on the Color class (the .NET one,
not the Autodesk one) should reveal how to
do it.
Tony
Tks
Dave
Message 13 of 16
in reply to: Thiss
On second thought, I think this is all he needs:
Autodesk.AutoCAD.Colors.Color entColor = //
System.Drawing.Color color = entColor.ColorValue;
/// kwb
Tony
int i =
Tks
Dave
Message 14 of 16
in reply to: Thiss
Tony,
Just a lame alias 🙂
using AcColors = Autodesk.AutoCAD.Colors;
"Tony Tanzillo" wrote in message
news:5575110@discussion.autodesk.com...
/// kwb
Tony
int i =
Tks
Dave
Message 15 of 16
in reply to: Thiss
Yep, Works for me 🙂
ltr = (LayerTableRecord)tm.GetObject(ltrId,
OpenMode.ForRead);
ltr.Color.ColorValue;
/// kwb
href="http://www.caddzone.com">
size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2008
through 2008
size=2>http://www.acadxtabs.com
"Kerry
Brown" <
size=2>kwb@home
> wrote in message
size=2>news:5575042@discussion.autodesk.com
size=2>...
kwb
<Thiss> wrote in message
href="news:5575062@discussion.autodesk.com">
size=2>news:5575062@discussion.autodesk.com
size=2>...
Tony
int i =
Which
.NET)?
Tks
Dave
Message 16 of 16
Thiss
in reply to: Thiss
Guys
All sorted tks - didn;t spot I could just pass the integer returned by the LookUpRgb into the Syste.Color.FromArgb method
Tks for help
Dave
”Boost
